Old 02-24-2013, 04:17 AM
groovq groovq is offline
Unhappy Eleven rack won't boot
Hi my eleven rack won't get past the boot screen! I've tried both reset options, unplugged USB etc but still won't get past the boot screen. The serial number ends in 0H
She lives a sheltered life not leaving the office so not misuse! Actually doesn't get used as much as it should!
I'm in Australia and got the unit via avid Australia/new Zealand because of multiple replacement units of another product so there is no retailer to contact for a replacement/fix.
After looking around here it seems quite a common issue. I'm not having much luck with avid and m-audio products it seems! Update: after looking at similar issues hear reminded me about the tuner not being recognised sometimes and stuck on one note.
Maybe I have one of the old dodgy batch
Any ideas for my next step?
Cheers, chris
i7 MacBook pro, 8GB ram, Eleven rack
Old 02-24-2013, 07:42 AM
kelco83's Avatar
kelco83 kelco83 is offline
Default Re: Eleven rack won't boot
Did you have it plugged straight in to the wall or was it on a upc, surge protector etc.?
Old 02-24-2013, 07:50 AM
Default Eleven rack won't boot
This does not seem a common problem.
Have you tried power cycling the Eleven Rack after it is removed from USB (remove the cable from the Eleven Rack entirely).
Have you tried all these... http://avid.force.com/pkb/articles/e...ow_To/en344703
Note the clue there as well that if certain buttons on the front panel are faulty/stuck down it can cause what you see. I would check/wiggle those buttons to see if they feel OK, have normal spring/click action and don't feel "worn out" or stuck down.
If that does not work, then it sounds like you already know how to get in touch with Avid Australia to arrange a replacement/repair. If it was mine and out of warranty I would probably open it up and just wiggle around the boards and a check the board interconnect cables and those front panel switches more carefully.
Darryl
Old 02-25-2013, 01:23 AM
Yep, tried both resetting options to no avail. All the buttons seem fine.
I thought it maybe the clock issue that I've seen on here since the tuner stuffs up and occasionally there would be no sound from time to time.
No response from avid aus/nz as yet before I consider taking the cover off.
Does anyone know what ending serial number unit had the clock/capacitor issue?
Thanks for the Advice
Chris
Old 02-25-2013, 01:29 AM
Chris
AFAIK the clock only affected rev E units (the last digit of serial number on rear panel). Yours is a rev H unit so not affected by that, even if it was rev E I suspect this failure to boot has nothing to do with sample clock problems.
Darryl
Old 02-25-2013, 05:00 AM
Darryl
I don't know if opening the 11R would void the warranty.
Don't discount doing this as my DSI PolyEvolver rack mount synth recently started going bonkers and opening it up and reseating all cables solved the problem. And this is a unit that sits in a rack and doesn't go anywheres. It's not so much that cables magically loosen themselves with a unit sitting in a rack but contacts can get a film on them that makes things intermittent.
Jack
QAPLA!
Old 02-25-2013, 05:52 AM
Also noticed the 2 red LEDs near the dsp chips are no longer flashing. The green one still flashes.
All buttons on the front seem fine.
Hoping to hear back from avid soon, maybe they'll repair it out of warranty for me, never know! As mentioned I've had back luck with avid/m-audio hardware failures!
Otherwise I'll try opening it up making sure everything is seated. I'm starting to have withdrawal symptoms!
Cheers,
Chris
Old 02-26-2013, 12:37 AM
Found this post of exactly the same issue. Serial of this guys unit is also 'H'
http://duc.avid.com/showthread.php?t=300999
Old 02-28-2013, 01:30 PM
Benoni's Avatar
Benoni Benoni is offline
that doesn't sound good!
Has Avid responded to your inquiry yet?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 02-28-2013, 07:09 PM
Not yet, giving them another call today. I've reverted to my old line6 tonePort in the mean time but after the eleven rack its well....yuk!
Ya never miss ya water till ya dry!
Chris
Eleven Rack won't Boot ac30fan Eleven Rack 21 08-03-2015 08:40 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Eleven Rack not recognized after a OS boot or reboot. tengai Eleven Rack 2 02-28-2012 08:39 PM
Eleven Rack won't boot completely cachosjazz Eleven Rack 4 11-13-2010 11:40 AM
