Old 08-06-2011, 03:27 AM
Asongwriter Asongwriter is offline
Default Help - Can't contain 'Reverb' with sends
Previously I could get pro tools to contain the reverb for any instrument in it's own space by using the 'pan' controls in the 'send window' for the given instrument. However now, the panning controls only adjust the placement of the signal in the entire stereo field, and the reverb can't be boxed into a unique space for it. Strangely enough, this isn't the case when using 'sends' for delays which are working as usual.
Can anyone give me any suggestions on what could be causing this issue, which occurs regardless of the plugin i use or it's settings.
Thanks
Louis
Pro tools 9.03, quad core pc, 4 gig ram, M-Audio Delta 1010lt
Old 08-06-2011, 03:32 AM
fakir_cz fakir_cz is offline
Default Re: Help - Can't contain 'Reverb' with sends
Isn't the FMP (Follow Main Pan) button enabled in the send window? If so, disable it.
BcA. Tomas Vitha
Sound Designer and Mixer
2010 Mac Pro 8-core Westmere, OS X 10.6.6, PT HD 9.0.3, Mbox 2 Pro, C|24
Old 08-06-2011, 05:03 AM
I've checked that, but it isn't engaged.
Old 08-06-2011, 09:47 AM
cneal92's Avatar
cneal92 cneal92 is offline
You have to pan the Reverb return (Aux In), not the send.
Panning the send to the reverb would only (attempt) to position the sound in the soundfield, but would still generate a stereo reverb. Just imagine an instrument in a room, even if you position that instrument to the far right, you would still hear the sound of the ER and Reverb in your left ear, it would just be a bit different than if you had positioned the instrument on the far left of the room. A stereo reverb should produce a similar result, but always sound in both channels. And the difference between something panned hard L vs. hard R can be quite subtle.
Now, if you loaded a multi-mono Reverb, you would only get reverb from one side or the other if you hard pan, and it would exhibit the behavior you may be after. As you pan more to the left the reverb generated by the L reverb will be stronger and the R weaker, which result in it seemingly to pan to that side.
Chris Neal :: South Plains College
.: Program Coordinator & Asst. Professor in Sound Technology
.: [email protected]
.: Pro Tools Certified Instructor
.: Pro Tools Expert Certified in Music
Old 08-11-2011, 05:29 AM
Thanks for your help Chris.
Louis
[IMG] code is Off
Sends default to -inf preference...resetting all sends to 0 Nathan W. Post - Surround - Video 3 07-15-2011 12:10 PM
Copying Sends Levels between sends Premo Pro Tools TDM Systems (Mac) 11 09-27-2008 10:03 AM
Stumped on this!! Auxilary Reverb Bus and sends.... Blake Henderson Pro Tools TDM Systems (Mac) 8 03-07-2008 11:42 AM
outboard reverb and effects using the aux sends and inputs A Chadwick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-22-2002 01:42 PM
About to sell PCM91 in favuor of Ren Reverb-Reverb One - is this a mistake? hokuspocus Pro Tools TDM Systems (Mac) 14 04-15-2002 02:07 PM
