  #201
Old 08-01-2013, 07:05 PM
Fezzler Fezzler is offline
Default Re: Best foot controller for use with Eleven Rack?
Thanks! Please check on the status of a stand alone software driver, VST preferred.
  #202
Old 08-01-2013, 07:33 PM
Huh? Stand alone and VST are kind of at crossed purposes. Are you after a stand-alone GUI or a VST GUI? Why would Avid do a VST format plugin based GUI?
Avid still need to deliver the promised Pro Tools 11 compatible UI, that will presumably be an AAX-64 plugin within Pro Tools 11. Whether Avid ever has plans to support a stand-alone software package has never been confirmed. It might well be that if Avid every does a stand-along GUI it may be the AAX-64 plugin wrapped with a stand-alone run-time package.
Darryl
  #203
Old 08-06-2013, 11:43 AM
mrgroovy mrgroovy is offline
I use the Mission Engineering EP11-S
I use it for volume and wah basically. No program changes b/c I do not use the 11R live.
2020 Mac Mini I7 3.2GHz, 36 GB Ram, Catalina, ProTools 2018.12.0 UAudio X6, Axiom Pro S49 MkII, Maschine MKIII.
  #204
Old 08-27-2013, 07:52 PM
DonaldR DonaldR is offline
Anyone tried a Line 6 Floor Pod Plus? I checked CC midi mapping and everything should work with 11R out of the box. Guitar plugged in 11R and Line 6 midi out to 11R midi in. Should worked as a backup too.
  #205
Old 11-20-2014, 09:52 AM
Burkemeister Burkemeister is offline
I just purchased a voodoo lab midi controller w/eleven rack, and I really like it so far.
  #206
Old 11-20-2014, 09:55 AM
  #207
Old 11-20-2014, 10:20 AM
Benoni's Avatar
Benoni Benoni is offline
Originally Posted by Burkemeister View Post
Nice setup
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #208
Old 11-26-2015, 02:35 AM
BobWells BobWells is offline
Hi all just joined the forum, my Eleven Rack is on it's way to me as I type, my question is has anyone any experience of using the Nobels MF-2 with the eleven rack.
  #209
Old 11-26-2015, 02:36 AM
All help greatfully received.
Bob
[SOLVED] FCB1010 Foot Controller (stock PROM) with Eleven Rack The Sentinel Eleven Rack 12 10-10-2018 12:18 PM
FS: Eleven Rack with FCB1010 Foot Controller J-mo Buy & Sell 0 07-08-2012 11:27 AM
Advice for Foot Controller and Rack/Case for Eleven Rack? udamann88 Eleven Rack 19 03-08-2011 06:24 PM
tonelab LE as foot controller for eleven rack? remis Eleven Rack 2 01-20-2011 02:03 PM
THE FOOT CONTROLLER for the Eleven Rack and any other rack modeler for that matter.. vkaxeman Eleven Rack 3 01-19-2011 04:13 AM
