Old 11-25-2009, 09:34 AM
midnightsun midnightsun is offline
Default Which Mac Pro to get?
I have the opportunity to upgrade from my G5 Quad to a new Mac Pro. Is it worth the money to get the most powerful processor (expensive), or would I be better off getting the most modest, but modern Mac Process and then getting extra RAM and additional harddrives?
It seems like the price goes up exponentially as one moves toward the bleeding edge of Mac technology and one can only stay on the bleeding edge for 3 to 6 months at best anyway.
I remember when my G5 was king (lasted for 2 month) and then the Intel Mac Pro was released. This is not a complaint as I am glad they they keep improving.
My biggest concern is not the actual cost, it is the effort that I am going to have to go to in order to get moved over to a new machine. The effort could take up a whole weekend or more!
Old 11-25-2009, 12:32 PM
lwilliam lwilliam is offline
Default Re: Which Mac Pro to get?
I have the dual 2.26Ghz quadcore and am pretty happy. 16 cores show up in PT. I think it was around $3300 base. I didn't want to spend $1400 for a small .4Ghz Ghz bump myself.
If you use a ton of VIs or modelling software like Amplitube, Guitar Rig, then the extra Ghz might be an advantage. I traded up from a dual 2.5Ghz G5 and the difference in power is huge.
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 11-25-2009, 01:23 PM
D'Animation D'Animation is offline
processor speed is a tough one (I'd go 8core for longevity as software will eventually be able to take advantage of them all ) but if your not afraid of the guts of a computer get the ram/harddrives from elsewhere (somewhere reputable like Other World Computing) and save your money that way
D
Old 11-25-2009, 01:59 PM
JFreak's Avatar
JFreak JFreak is offline
Get the cheapest one! This is a no-brainer IMO
Janne
Old 11-25-2009, 06:55 PM
Eric Lambert's Avatar
Eric Lambert Eric Lambert is online now
Originally Posted by midnightsun View Post
I remember when my G5 was king (lasted for 2 month) and then the Intel Mac Pro was released.!
G5s were king for a loooong time, and they're still perfectly adequate machines for ProTools. You jumped on the bandwagon late in the game if it was 2 months before the Intel release.
Old 11-26-2009, 04:03 AM
Ya, I moved into a DAW from RADAR II. I am actually fairly content with the G5. I am just in need of a computer (not a DAW) for which the G5 would serve well. So the new, more powerful computer may as well be for the DAW. In terms of waiting for the software to catch up with the "more powerful" computer, sometimes that never happens. I remember the G5 Quad and the hype that programs would be written to take advantage of the 4 processors. Logic Pro 7 & 8 never rose to the occasion nor did photoshop.
Old 11-26-2009, 06:07 AM
Ian Palmer Ian Palmer is offline
What else do you have with your G5? Mojo? Plugins? etc etc.
We tried to upgrade a G5 to Mac Pro and discovered we would need to spend a lot more than just the machine upgrading PT, OSX and our plugins. The exact same version of OSX, PT and plugins will run fine on both computers but the Mojo needed a later version of PT to work on the Intel Mac.
Make sure you find out if everything will work on your new system before splashing out otherwise you may need to fork out even more.
Ian Palmer
Sound Designer & Dubbing Mixer
@ianpalmersound
Website
IMDB
Old 11-26-2009, 07:40 AM
youngas75 youngas75 is offline
One word of warning, check your Accel cards. If they are PCI then they won't fit into the new mac pro machines as they are PCIe. I hope I'm not stating the bleeding obvious but I have one G5 and one Mac Pro and they both needed different cards.
6 x HDX
21 x Vanilla
D-Command ES
S6 M10
SSL Duality, AWS924, AWS948, Nucleus
All Mac
Old 11-26-2009, 02:38 PM
All I am running is an PTHD3, PCIe cards, and D Command. I occasionally run Logic Pro
Old 11-27-2009, 01:05 AM
Aye, we're on HD2 7.3.1 with PCIe and a ProControl. As I said before it all swapped across perfectly. I installed all the software on the MacPro. Swapped the HD cards across, plugged it in and fired it up. The only problem was the Mojo.
Ian Palmer
@ianpalmersound
Website
IMDB
