Old 02-13-2013, 10:52 AM
sjafarzadeh sjafarzadeh is offline
Default Pro Tools 10 won't open session file (Created on a newer version)
Hi guys,
Encountered an unusual problem. When trying to open a Pro Tools 10 file on a Pro Tools 10 system, I keep receiving the message that "This document could not be opened because it was created on a newer version of Pro Tools". This is only happening to one particular project file. It was running perfectly fine yesterday but hasn't worked since it was last saved. It is a .ptx file and all the systems I've tried to open it on are Pro Tools 10.
Does anybody have an idea of what the issue could be?
Thanks.
EDIT: Pro Tools* in title
Old 02-13-2013, 11:14 AM
Phil Ogden Phil Ogden is offline
Default Re: Pto Tools 10 won't open session file (Created on a newer version)
You could try importing the session data into a new session.
Old 02-13-2013, 11:21 AM
I've tried doing that but it won't allow it because of the same error.
Old 02-13-2013, 11:58 AM
Craig F Craig F is offline
can you open a session backup file?
Thank you,
Craig
Old 07-16-2014, 11:13 AM
hecklerhouse hecklerhouse is offline
Default Re: Pro Tools 10 won't open session file (Created on a newer version)
I am encountering the same error message running pro tools 11.1.2 and trying to open a session created with pro tools 8. All the other sessions from the same period open fine, including one of the saved pro tools session files in the SAME SESSION FOLDER. (I will save xyz_march_4_14_1 and then xyz_march_4_14_2, etc.) Very strange... did you ever figure out the issue? Thanks
Old 07-16-2014, 12:03 PM
does the 8 session have it's .ptf extension? if not add it to the file and try that
otherwise an auto-backup is your best bet
Thank you,
Craig
Old 06-05-2023, 04:41 AM
Kreed Kreed is offline
I'm having the same problem 9 years after this thread was started. You'd think Avid could have a fix for this by now. I literally created the project on the same machine with the same version of Pro tool, spent 4 days mixing, and then the next day it won't open. This seems like a pretty important glitch for Avid to pay attention to!
Old 06-13-2023, 03:30 PM
Well, consider this was a problem with certain versions of PT 10 which is now how old? I can't remember seeing this(its been that long). One option that is worth a try:
Create a new blank session but at a different sample rate(IOW, if the original session is at 48K, make this new one 44.1K, or vice versa) and try to import session date, telling Pro Tools to apply SRC(Sample Rate Conversion). Also, if you are simply trying to import all tracks at once, instead, import 10-12 tracks at a time(or fewer if its a small session). Doing this might pin the problem on a single track(which could be easier to solve). I feel your pain and hope you get lucky!
Old 06-14-2023, 11:24 AM
dfoxhoward3 dfoxhoward3 is offline
I'm experiencing the identical error message while using Pro Tools 11.1.2 and attempting to access a session that was initially created with Pro Tools 8. kerassentials review
This session file was created by a newer version of Pro Tools [7.4.2f109] olivergodfrey Pro Tools M-Powered (Mac) 3 02-12-2013 04:53 AM
Can not open last session !It says it was created with older version of PT !?! WTF ?! mrpollack Pro Tools 10 2 12-19-2011 10:45 AM
Can't open session it's created with an older version of PT James Drake Pro Tools TDM Systems (Mac) 6 08-22-2011 08:17 AM
File could not be opened because it was created with a newer version Bob DeMaa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-11-2009 01:47 PM
"Session File Created in a Newer Version of ProTools"? nemisis63 Pro Tools TDM Systems (Mac) 4 08-30-2007 12:26 PM
