Old 12-09-2020, 06:36 AM
timmy4402 timmy4402 is offline
Default Waves Tune - Moving Clips after AutoTuneq
Hello, I have a massive vocal project with 60 background singers on different audio tracks. Almost all of them are getting autotuned with Waves Tune.
To do the individual work, I cascaded each audio clip across my session so they don't sit at the same time at the moment. For example, if each clip if 5 seconds long .. I have the first one starting at 0:00, then then next one is on a new track and starts at 0:05, the next one is on a new track starting at 0:10 and so on.
Now that everything is set the way I want it, I am trying to assemble pieces back on top of each other. but when I move the clips .. pretend all back to 0:00 ... the Waves pitch shifting doesn't move with it. It is stuck at 0:05 and 0:10 using my example.
How can I move both the clip and the Tune information together??
Thanks,
Tim
Old 12-09-2020, 12:48 PM
leftalive leftalive is offline
Default Re: Waves Tune - Moving Clips after AutoTuneq
Why not leave the clips on their own tracks where they need to be in the arrangement, and just highlight each section you want to tune. Use the audio suite version of Tune and it'll import only what you have highlighted. Once you commit the audiosuite'd tuning to the highlighted section, it'll create a tuned copy of the region right there, in place.
Seems much easier to me.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 12-09-2020, 02:02 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Also note you can save the AS tuning as preset for recall i.e. v1at
If in track doesn’t Waves Tune require Waves Rewire on a dummy track or is that Old-tech-Waves?
Old 12-11-2020, 05:14 AM
simon.a.billington simon.a.billington is offline
This is what you need ARA support for. It allows plugins to communicate with the DAW and keeps it up to date with any changes, including moving your edits.
Unfortunately WavesTune doesn’t support it yet, I can’t remember if ProTools does either. I think your best way forward would be to save a copy and render Tune before moving the clips or you could use the delay plugin to “undo” any timing changes.
Neither way is ideal, though.
Old 12-11-2020, 01:12 PM
fasttraxx fasttraxx is offline
Thanks,
Tim
I had this happen to me before and if I remember correctly Waves tunes needs Pro Tools transport set to 1/4 notes to work properly
Thanks and God Bless!
Y.B.I.C.
Bill
Old 12-11-2020, 03:05 PM
No ARA in PT yet, but I think its in the works. I would also suggest AudioSuite and render in place*. As an alternative, if everything sounds good using the inserted WavesTune, Commit up to This Plugin and de-select the option to consolidate(which should give you a new track with all the tuned/rendered audio clips in place).
*I think you may have done yourself a disservice by splitting all the clips out like you did(I think it would have been more efficient to treat the clips in their original locations)
HTML code is On
Getting a status bar when moving clips left/right lvly5t Pro Tools 2019 3 06-19-2019 07:10 AM
Moving clips vertically paldry Pro Tools 12 6 08-14-2018 08:20 AM
moving clips fmilian Pro Tools 11 6 05-08-2015 05:11 AM
moving all the clips! TakenGrace Pro Tools 11 6 06-21-2014 01:07 PM
Waves Tune and Auto-Tune Unhappy With HDX? Logichead Pro Tools HDX & HD Native Systems (Mac) 2 11-25-2012 11:42 AM
