Old 08-03-2018, 08:51 AM
adam79's Avatar
adam79 adam79 is offline
Default Acoustica Audio Aqua - Sample Rates
In the Magenta 4 manual it says that, "the two sample rates provided are 96 and 44.1Hz." Does this mean that running a session at anything but those two rates isn't recommended? I always record at 48Hz/24bits because I have an Apollo Duo; it runs out of DSP too quickly at 96Hz. I'm just trying to figure out if I should switch my sessions to 44.1. Thanks.
Old 08-03-2018, 11:52 AM
WernerF WernerF is offline
Default Re: Acoustica Audio Aqua - Sample Rates
Don't know about Magenta 4 but switching to 44.1 should make no audio difference at all. I would do that just in case.
Old 08-03-2018, 12:31 PM
adam79's Avatar
Right on. Are the two sample rates they refer to the ones used for gathering samples for the plug?
HTML code is On
Pro Tools 11.3.1 crashes when importing audio from different sample rates feliponk Pro Tools 11 8 03-24-2015 07:01 AM
Audio playsback at slower speed, but sample rates are correct lblstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-12-2009 01:25 PM
CHANGING SAMPLE RATES ON EXISTING AUDIO FILES John calvert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2006 07:16 AM
Comparing Bit-rates, Sample-rates, and convertors - Telling the difference? stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-05-2003 08:36 AM
mix audio with different sample rates usinare Pro Tools TDM Systems (Mac) 1 03-26-2002 08:46 AM
