Old 07-11-2018, 11:10 AM
Charu1 Charu1 is offline
Default No input in IO settings. Pro tools 12
PRO TOOLS VERSION: 2018.4.0
MAC: macOS high Sierra
Version: 10.13
MacBook Pro: (13-inch, Mid 2012)
Processor: 2.5 GHz Intel Core i5
Memory: 8GB 1600 MHz DDR3
MBOX MINI: 3RD Gen
Hello, I am still kinda new to pro tools/recording.
I am using a macbook pro 2010 & an mbox mini. With a phantom mic. Phantom power is enabled. The mic/line button is up. The sig/clip light on the mbox blinks yellow when I sing or make a sound near the microphone, however when I try to record enable the track to it says "1 audio track could not be record enabled because it doesn't have both input and an output assigned."
I have gone to IO settings & clicked default as suggested online. There is an output & buses but no input at all. The "new path" "new sub-path" "delete path" "default" buttons at the bottom of them input page are greyed out.
I have researched but having no luck here, any help would be appreciated.
Thanks!
Sent from my SM-G950U1 using Tapatalk
Old 07-11-2018, 12:05 PM
Default Re: No input in IO settings. Pro tools 12
Is the Mbox actually selected as the "audio engine"? (Setup>Hardware menu)
HP z820 12 core, 64GB RAM, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs, Warm Audio and Midas..............................
Old 07-11-2018, 12:48 PM
Yes. Also when creating a new track, "mbox mini" doesn't appear as an option in the dropdown menu at the right hand bottom side that says "I/O settings"
Old 07-11-2018, 01:44 PM
junkgear's Avatar
junkgear junkgear is offline
Can you post a screen shot of your track; specifically the input and output settings?
It sounds like you set things up properly, but just to make sure.
1.) Launch ProTools and hold the N key down while it is loading. This will refresh the hardware and prompt you to choose an audio device in the PlayBack Engine settings.
2.) Select your MBox as your device in Playback Engine.
3.) Open Settings -> IO
4.) Click on the Input tab and press the Default button.
5.) Click on the Output tab and press the Default button.
6.) Press Ok to close the IO settings.
Now create a new blank project. Leave the I/O Settings for the new project to Last Used.
In your new project, create a Mono audio track.
The track will have both an Input and Output selection. Ensure your input is set to the input where your mic is connected. Your output will be something like Default L/R.
Now record enable the track and see if it passes audio.
Will K
System Details
Old 07-11-2018, 07:19 PM
I'd like to see a screen shot of the Hardware Setup page(in PT>Setup>Hardware). The shot you posted tells nothing about the audio engine. But it DOES show that your sessions are going to a location that doesn't make sense(to me, anyway). Where are your sessions(and are they on a separate hard drive)?
Old 07-17-2018, 05:37 PM
Thanks for the detailed response!
I followed your instructions step by step but when I get to the 'Input' tab in the 'IO' settings the option to press 'default' is greyed out. As shown in the photo below.
Old 07-17-2018, 05:39 PM
I have been saving my sessions on a file on my desktop.
Old 07-17-2018, 05:56 PM
Thanks alot for the help btw!
I have updated the OP with my system info.
Version: 10.13
MBOX MINI: 3RD Gen
Old 07-17-2018, 05:57 PM
Updated the OP with system info
Version: 10.13
MBOX MINI: 3RD Gen
Old 07-17-2018, 06:03 PM
@junkgear
First photo is input, 2nd is output
HD OMNI input settings i/o hydraonstimpac Pro Tools HDX & HD Native Systems (Mac) 2 03-31-2013 07:46 PM
input settings problem rick schaulyoder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-03-2011 11:20 PM
I/O input settings not defaulting...? Jsalam112 Pro Tools TDM Systems (Mac) 0 10-30-2005 08:54 AM
Default Input settings Ludicrous Speed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-01-2004 02:25 AM
Pod 2.0 unit best input settings KamaSutra77 General Discussion 0 04-08-2001 08:52 PM
