Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 07-11-2018, 12:23 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Default macOS 10.13.6 with 2018.4
I know it was just released. Did anyone the plunge? If so, how are things running?
Pro Tools 2018.4 | OS X High Sierra | RME
Old 07-12-2018, 10:05 PM
mattrixx mattrixx is offline
Default Re: macOS 10.13.6 with 2018.4
Justy fine here. 2013 MacPRO and 2017 Macbook Pro
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
Old 07-13-2018, 02:07 PM
zerodistraction zerodistraction is offline
Working fine here with 2018.4. Use at your own peril though as our hardware and plugin configs are different. Personally I’ve never had issues with patching macOS. It’s only jumping from one major version to another where serious problems can happen. Maybe I’m lucky.
Old 07-21-2018, 12:42 PM
VRW VRW is offline
+1
No problems here as well.
2014 Macbook Pro i7 Quad, 16GB Ram, Apollo Thunderbolt series 1, UA Octo Satellite, macOS 10.13.6, Pro Tools 2018.4 HD+Native
Old 07-23-2018, 11:46 PM
TNM TNM is offline
Ok, since you guys have no issues, may I at least ask what latency you are running?
1) iMac Pro 3.2ghz 8 Core, 64GB Ram, 2TB SSD, OS 10.13.6, Caldigit TS3+ Dock, Startech USB-C raid enclosure w/ Crucial MX500 1TB x2, 1TB SSD-R G Tech x 2, Samsung 860 Pro 512gb Audio Drive in USB C Enclosure, TBolt Apollo 8 x 2, TI2 Desktop, MoxF6, tons more midi synths, PT 2018.7/Cubase9.5.
2) MBP 2.8ghz i7 quad, 16GB ram, 1TB SSD, OS 10.12.6, PT 2018.7, Logic 10.4.1,Internal Sound, TBolt SSD 512GB.
Old 07-25-2018, 11:33 AM
I generally run at 256 when tracking.
Old 07-25-2018, 12:40 PM
ktmcgraw ktmcgraw is offline
I did. Now I'm having latency while recording even though low latency monitoring is turned on. While recording I can get it to stop by turning low latency off and back on again, but every time I hit record there's latency again. No good. Anyone have a solution?
Old 07-25-2018, 03:24 PM
DetroitT's Avatar
DetroitT DetroitT is offline
"... every time I hit record there's latency again. No good. Anyone have a solution?"
Does your Master fader have zero plugins?
(Help us Help You)<<<click here
Testing:All APSF but Working Audio
Pro Tools U-2018.12 MacOS 10.13.6
-10.14.3 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire 7950 MacEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
Surround-music-design-creation.
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Old 07-26-2018, 03:39 AM
Bfrink1971 Bfrink1971 is offline
It appears to be a bug.
http://duc.avid.com/showthread.php?t=396670
Try turning quick punch on and then off again. This seems to fix the problem for me, at least until I arm another track for record.
OS 10.13.5 - will PT 2018.4 or .5 work well or stay with 2018.13? blankpro Pro Tools 2018 4 07-11-2018 08:22 PM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb Pro Tools Software (Mac) 0 06-27-2018 07:33 AM
Weird UI glitches in 2018.3 on macOS 10.13.3 Chingy Pro Tools 2018 6 04-06-2018 06:17 AM
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 05:41 PM
Sluggish Zoom in/out + scrub issues 2018.1 (MacOS 10.13.3) Hrmonik Pro Tools 2018 0 01-28-2018 11:35 AM
