Old 05-06-2020, 08:18 PM
LukeHoward LukeHoward is offline
Default Hardware/sample rate errors on MacPro7,1
Since upgrading, I'm getting a "Pro Tools detected the number of HDX cards changed" errors when changing sample rates. I imagine this has nothing to do with the Mac but rather also upgrading to HDX2 (MTRX hung off the first card, Avid HD I/O off the second). DADman is set to follow sample rate from DigiLink 1, and the MTRX is the master clock. I'm on Pro Tools 2020.3.
I think this is the relevant error but I could be wrong (it's the last one before Pro Tools quit).
Code:
8078.367636,dc003,0e10: CFicMariaTDMDeck::ErrorStop - err: -6080
8078.367752,dc003,000f: CDAEErrorHandler::DAEErrorStopProc - err - -6080
8078.372708,00307,0d02: Performing TCommand: CHandleErrorStopCommand
8078.372769,00307,000f: CDAEErrorHandler::HandleErrorStop - mErrorStopOSErr - -6080
8078.372916,00307,0e10: ReportDAEError - iDAEError - -6080
https://lukehoward.com/
Old 05-06-2020, 09:17 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Hardware/sample rate errors on MacPro7,1
I don't have HDX or MTRX, but I've had sample rate weirdness. When Pro Tools is closed and you open "AvidAudioServer", make sure the interfaces are clocked correctly. I had an issue where my 192 kept reverting to 192k although everything I did and needed was 48k. Once I changed it from the audio server, I didn't have any issues where my AES wouldn't feed my speakers or sync issues with other interfaces. Worth a look?
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 05-06-2020, 09:33 PM
Ah yes, I have a sneaking suspicion it could be Pro Tools momentarily releasing the hardware and their CoreAudio drive taking over in the interim. Everything's clocked together as far as I can tell but, I will simplify things and try with just the MTRX and see how that goes.
Old 05-08-2020, 11:39 PM
Still seeing this after killing the CoreAudio driver Seems to be AAE error -6080.
NB: error is the number of peripherals connected to the HDX cards changed, not the number of cards. Interestingly I am seeing SDI O PIO Floating Point / PIO TDM Loop / TDM PIO Loop Int B-A fail on the primary (newer) HDX card. Hmmmmm.
Old 05-09-2020, 05:46 PM
This appears to be MTRX-specific, too. If I just connect a HD I/O to the first card there are no issues changing sample rate.
Lynx aurora and pt 11 sample rate errors soundroi Third Party Interfaces 1 03-01-2015 05:33 PM
Sample rate setting on hardware gets forced to 44.1 by PT8 Ludia Pro Tools M-Powered (Win) 6 12-26-2012 09:09 PM
Sample Rate in Hardware Setup protollo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-06-2009 02:48 PM
"mixed sample rate "errors in DT 2.0 Michael Klinger Post - Surround - Video 4 11-20-2002 09:44 AM
Hardware Sample Rate Conveters meshtheflesh Tips & Tricks 10 02-14-2000 07:08 AM
