#2431
Re: Best Laptops for PTLE
On every system I have ever used that has a WiFi card, and on many systems that I haven't actually used, but helped online with, keeping the WiFi card enabled always eventually causes -6085 errors (sooner on some systems than others).
#2432
My system drive is 7200 rpm...I am not recording to this drive.
My firewire drive (MyBook Western Digital) is 5400 rpm. Do you really think upgrading my external drive to a 7200rpm will make THAT much difference? I can't even record one second with the 5400rpm... Do you think a new external hard drive will fix the firewire underflow error I mentioned? Because it's asking me to remove items from my system firewire bus...that doesn't sound like an external hard drive problem to me. I mean, I'll buy a new one, but could it really help that much? Nish: How do I set my USB controllers to it's default windows drivers? I am running Windows Vista 32 bit, not XP. The AVID site said that Windows Vista 32 bit only was supported. Should I try XP anyway? I have already ordered another 2 gigs. Thanks for helping me guys, please continue to give input on anything you feel necessary. |
#2433
Where does it say that?
#2434
http://www3.digidesign.com/index.cfm...&itemid=37251\
It did not make the list of XP compatible computers...what do you think? Try it anyways? I have had better luck with XP in the past with other pc's...but they were desktops. What do you think about this hard drive? http://eshop.macsales.com/item/Other.../MEAQ7750GB32/ Yes? No? Do I need the 32mb cache or would I be ok with the cheaper 16mb cache? |
#2435
Keep in mind that the current version of Pro Tools is the very last that will support Vista or XP. I would definitely recommend Windows 7 above both at this point. Quote:
#2436
http://www.wiebetech.com/home.php
Your link was one I considered however the wiebtech is the one I have for backup only! as it has a fan for cooling in which is huge. You have a false sense of security without cooling and you might lose the hard drive. Im surprised that your still messing with a 5400 rpm drive when you have already been educated about this previously. I dont understand the Vista operating system. This operating system even with protools out of the picture was something I would never mess with either, as it was a complete failure for Microsoft and most people. |
#2437
For the usb controllers you go to system, hardware, device manager, universal serial buss controllers, choose the usb controller/update driver/install from specific location/dont search, i will choose.../next/ then choose standard enchanged controller. Anyhow I don't know if this is the same in vista though, all I know is that I installed vista once on some laptop and it the biggest crap OS I ever come across in my life. XP still kicks ass for me (tweaked), though with the latest anouncement that pt 8.0.4 is the last xp supported version I would upgrade to windows 7 64 bit. with upgrade I mean buy an OEM version of W7 not an upgrade package though, otherwise you would be stuck with installing vista first every time you need a fresh install. Good luck, cheers |
#2438
Hayesland,
I did upgrade my system hard drive to a 7200 rpm after talking to you. I was unaware that the MyBook was only 5400 at the time. But here's the deal. I can't even LISTEN to a session on my USB Mbox micro drive with my new 7200rpm system hard drive. I'm really hoping you guys are right...that an upgraded 7200rpm external hard drive will somehow fix all these issues...it's a little hard to believe. I mean what would my EXTERNAL hard drive deficiency have to do with a USB Mbox micro listening device? I guess my last ditch effort will be to try XP. I'm growing weary... |
#2439
Not since version 8.0.4 was released, no.
#2440
It's been a while since I last looked at trying to get PT to successfully work on my hardware... Since looking again, a few things have changed - Win 7 64-bit is supported, the Mbox has been dropped and... Hardware compatibility seems to have been simplified - am I understanding that right?
The problem I had previously with PT running on laptops is that Digidesign's recommended hardware list was so out of date that I couldn't purchase any of their recommended laptops - assuming those particular models were available here in the UK. So, am I free to pick up a laptop of my own choosing now, if I ensure it can connect to an Mbox 2, has enough RAM, an i5 or i7 processor and a 7200rpm HD? Or is it not as simple as that still? |
USB support with Pro Tools 9 Laptops | moldenke | Pro Tools 9 | 4 | 11-18-2010 04:46 PM |
Dell Laptops and Pro Tools | sgladm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-03-2006 10:32 AM |
Best laptops for Pro tools | felixflank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-07-2006 06:41 AM |
alien laptops and pro tools | geefive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-29-2006 10:17 AM |
Pro Tools and Apple laptops | Jsalam112 | Pro Tools TDM Systems (Mac) | 1 | 04-08-2002 09:28 AM |
