Old 05-05-2022, 02:25 PM
HowHoffman's Avatar
HowHoffman HowHoffman is offline
Default Two Big Problems with 2022.4
I tried this with Monterey and with Big Sur with the same results:
1) The Universe pane is now completely useless. As you can see with the first screenshot, clicking, dragging, anything I try to do with the mouse won't work, chiefly because the pane is dead. (I submitted this to Avid and they're reporting it as a bug.)
2) The drop-down menu for AudioSuite is the only one that has a white font on a gray background (in the screenshot) - the rest have black characters. This is in Monterey. The white font is ALSO on the plug-ins themselves, making choosing a real problem.
Can anyone help me out of these problems? Thanks!
File Type: jpg Screen Shot 2022-05-05 at 5.23.39 PM.jpg (40.1 KB, 0 views)
File Type: jpg Screen Shot 2022-05-05 at 5.14.32 PM.jpg (44.0 KB, 0 views)
Old 05-05-2022, 02:43 PM
Default Re: Two Big Problems with 2022.4
You on Intel or Apple silicon? Your system info is out of date we can't guess.
2022.4 on Intel/Big Sur I see Audiosuite menu fine. edit: Works OK with dark and classic theme.
Universe pane, wouldn't know what it was or what to do with it if it bit me.
What troubleshooting have you tired for the audiosuite menu? Trashed prefs? Have you tried with the classic theme? undoing any theme customizations if any were done?
If you get support incident number or bug numbers for stuff please post those here.
Old 05-06-2022, 01:48 AM
HowHoffman's Avatar
I’ll definitely post the result of the bug report.
It’s the last gen Intel iMac Retina 27” (3.0ghz 6-core i5). And both happen in both dark and classic modes. I’ll try flushing the prefs and let you know if that works.
The only things outdated in my profile were the MacOS version and the Pro Tools version. Everything else in there is current. Thanks.
Old 05-06-2022, 02:04 AM
HowHoffman's Avatar
BTW, the Universe window is that bar at the top of the edit screen that gives you a flyover view of your session. (Tracks, markers, etc.) You’re supposed the see the tracks in there and you can jump around in the session with a click. It’s where the cursor is in the first screenshot.
Old 05-06-2022, 05:34 AM
ejsongs ejsongs is offline
I rolled back to 2021.12
Old 10-12-2022, 03:49 AM
HowHoffman's Avatar
Happy to report the 2022.9 update to Pro Tools Studio finally fixes the universal window problem. Thanks, Avid.
Sadly, the white text problem is still there.
Old 10-12-2022, 06:05 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
Not that I'll be much help, but; I had the same issue PLUS the menu bar (ya know file, edit, etc.) was missing, as in not there at all.
I trashed preferences and did a reboot and now everything seems to be copasetic. Not that I am suggesting this is a fix for you, but it did fix things for me.
Just as a side note, I ALWAYS shut my machine down after my daily back-up. I don't know if that makes a difference or not, but it's like chicken soup for a cold....it can't hurt.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Old 10-12-2022, 01:50 PM
nednednerb's Avatar
nednednerb nednednerb is offline
I had the issue with Audiosuite menu "whiting" out too.
I happened to randomly fix it..... Maybe by doing the following two things, which do seem related tangentially:
In System Preferences > Accessibility > Display....
Do you have "Reduce transparency" and/or "Display contrast" settings in use?
I turned my Transparency setting off, and Contrast to normal. Then I realized "I don't like this" and I reduced transparency again and increased contrast slider to first notch..
Later, when I went to use Audiosuite menu, it was easy to see again! I am NOT sure though that what I describe above did the trick. But it seems fixable... somehow or other..
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 10-19-2022, 07:57 AM
HowHoffman's Avatar
Sad to say, that didn't work and didn't improve with 2022.9.
2022.4.0 won't load on Mac edkocol Pro Tools 11 05-08-2022 05:29 PM
2022.4 bugs? Soundworks UK Pro Tools 8 05-07-2022 06:18 AM
D-Command with 2022.4 Third Eye Studios ICON & C|24 14 05-06-2022 08:29 PM
Eucon 2022.4 Cheesehead Avid S1, S3, Dock and Control App 9 04-28-2022 08:54 AM
