Old 04-11-2022, 05:18 AM
mnstudio mnstudio is offline
Default How to make the project tempo matching the midi performance?
I would like to record a piano midi track without the constriction of the click, so to be free of fully expressing my interpretation. So I would record it freely but, afterwards, I would like to make the project tempo matching the performance. How can I do? Is this possible? With beat detective?
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Old 04-11-2022, 05:23 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
Default Re: How to make the project tempo matching the midi performance?
I have found that the easiest way to do that is, once you have recorded your performance, export the midi. Then import it back with the include key etc. option.
That will map it for you.
Or, use Melodyne and export a tempo map and import that into Pro Tools.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Old 04-11-2022, 05:56 AM
Bigbottomend Bigbottomend is offline
And THAT's why I keep coming back here! Great tips CB :)
Old 04-13-2022, 04:00 PM
Franklyn Franklyn is offline
Can you explain a little bit deeper. What did you mean with "Then import it back with the include key etc. option."
how can PT know where the metrum is in a free piano midi track?
Old 04-13-2022, 06:32 PM
Cowboy Bob's Avatar
Yeah sorry for the confusion, PT can’t. I was thinking of imported midi from other sequencers.
Use Melodyne.
Bob
Old 04-13-2022, 08:31 PM
Extreme Mixing Extreme Mixing is offline
Logic will do this stuff easily. So worth it to have around for $200. Much cheaper than Melodyne, too. And I own and love Melodyne!
Steve
Steve Shepherd
Extreme Mixing
Old 04-14-2022, 09:29 AM
daeron80 daeron80 is offline
In the absence of Melodyne (I assume the light version that comes with PT won't suffice) or Logic, the best way would be to go through your piano performance beat by beat, copying one note that lands on each beat to a new track. Where there are beats that have no note played on them, add a note to the new track manually. Then use Beat Detective to construct a MIDI map. Just be sure to change your original track to Sample based before you do anything else. Not Tick based, or it will mess it up.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 04-15-2022, 08:18 AM
This comes up all the time, and there's probably a zillion YT vids about how to do it (though no idea if any of them are any good). Sort of depends on how much "granularity" you need, but Steve is right that Logic's tools are better for this. If I wanted to do it in Pro Tools, and Melodyne didn't get me there, I think I'd go through and mark out 8 bar chunks just using "Identify Beat" which would be fast and easy. Once that's done I think I'd see if Beat detective could get me to the Bar level by letting it chew on each 8-bar chunk. If BD can't get it then you'd have to just use more Identify Beat commands to get it to the level of precision you're after. And as David points out, be sure your tracks are in Sample mode (not ticks) before you do this.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Tempo matching midi mikeymo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-03-2010 12:01 PM
PT8 - Make Double/Half Tempo of Midi File 25ghosts Pro Tools TDM Systems (Mac) 2 02-16-2009 04:08 AM
Matching Up Tempo's -- Like Acid 6.0 Pro Kbone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-12-2006 01:38 PM
Tempo Matching an LE Feature? Blue Ridge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-22-2004 05:11 PM
Tempo matching - problem India001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-13-2001 05:58 AM
