Old 08-07-2017, 04:55 AM
gdkaufmann gdkaufmann is offline
Default Yellow Track Borders - Can't Select Anything
Apologies for the newbie question, but I really can't find an answer to this in the forum or elsewhere online. I suspect it may be SO obvious, that nobody else has thought to raise a question.
I'm using PT11.3, and have suddenly started getting a yellow border around any track or clip that I try to highlight and move, and seem to be unable to select individual tracks, though no group buttons are selected (that I can see).
I can drag the cursor and highlight a section within a track, but that's all.
I'm wondering if anyone has an idea what box I've inadvertently ticked, or set up incorrectly? Also, it's now happening across all of my sessions, not just this one.
I've attached a pic. of what I'm seeing onscreen.
Thanks in advance for your help.
GK
Old 08-07-2017, 06:44 AM
suicune suicune is offline
Default Re: Yellow Track Borders - Can't Select Anything
Think you've accidentally switched on your 'ALL' edit group. Look in your group list on the bottom left of the edit window - when 'ALL' is bordered in grey it is switched on. Click on it once to disable it again.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Old 08-07-2017, 06:48 AM
Thanks. That seems to have done the trick.
Mouse without Borders bootybandit Windows 0 09-14-2011 12:44 AM
Yellow track frame borders in ProTools???? Apprentice->Master Pro Tools M-Powered (Win) 3 04-01-2010 03:50 PM
"select next/previous track" "rec enable track" key command? maufau Pro Tools TDM Systems (Mac) 6 04-22-2008 05:08 PM
Track meter instantly goes to yellow Thedy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-22-2006 12:05 PM
Track meter goes instantly to yellow Thedy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-21-2006 10:50 AM
