Old 05-08-2017, 07:07 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default D-Command - track name
Guys I must have messed something up and for the life of me I can't figure it out
Why does my track name not show up?
I'm positive it was my fault but I don't know how to get it back.
And at the time it disappeared I was removing send's across my mix
Fader 1 scribble strip....it's the only one like that in the mix
Daniel
Old 05-08-2017, 09:26 PM
Barry Johns Barry Johns is offline
Default Re: D-Command - track name
Its set using the Dsp Mode just to the left of the EQ Knobs, above the Focus Channel Section. Keep pushing the button until the track names come up.
The D Command is basically telling you, you need more cow bell, so it messes with the track names to draw attention to it......
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 05-08-2017, 10:03 PM
YYR123's Avatar
Yeah it's not that, b/c I've cycled through those settings
I changed something while I was assigning outputs and sends.....and I don't know how or what I did, oops
Daniel
Old 05-08-2017, 10:46 PM
Stig Eliassen's Avatar
Have you tried a power-cycle? I've had Console Gremlins™ go away after turning the console off/on.
Old 05-08-2017, 11:02 PM
PTPerson PTPerson is offline
Yep I reckon it's a gremlin.
Occasionally happens on my D-Control.
Old 05-09-2017, 05:24 AM
Drew Mazurek's Avatar
What happens when you bank/nudge? Does it follow the channel?
Power cycle?
All sessions or just this one?
www.drewmazurek.com
Old 05-09-2017, 05:30 AM
Southsidemusic's Avatar
Happened a few times on our D-Control ES 32 and we had to reset the main unit so maybe try this:
For main unit: Go to Utility>Reset and hit OK to confirm the reset. For Fader pack: When Pro Tools is not running, hold down these modifier buttons (on the control surface) in order: Shift + Alt/Command + Win/Option. Next press the Select button associated with the Reset command and confirm the choice by hitting the Select button below.
Hope you find the issue asap.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 05-09-2017, 08:07 AM
YYR123's Avatar
Thanks guys for the input.
Yes when nudging it follow that track. So that tells me it's been modified in some way.
Power cycling didn't work. Only on that session....
Never done a reset I will have to try that, I'm only on the Main unit....8faders only
Daniel
Old 05-09-2017, 08:21 AM
So, it's specific to that track.
Try making new session and importing that track.
Try changing that track's name.
www.drewmazurek.com
Old 05-09-2017, 08:30 AM
Have you replaced the name with a space? The strip will turn black if so.
D-Command Track Select antonis Post - Surround - Video 4 07-21-2014 02:19 PM
Key Command for next track selection ? Firechild Pro Tools TDM Systems (Mac) 6 06-23-2012 12:43 PM
Command 8 Track Banks mman00 Pro Tools TDM Systems (Mac) 2 02-15-2011 07:32 AM
"select next/previous track" "rec enable track" key command? maufau Pro Tools TDM Systems (Mac) 6 04-22-2008 05:08 PM
Track 1 on Command 8 going all over the place... Rated R ProControl, Control|24, Command|8 0 03-17-2007 11:10 AM
