Old 04-24-2017, 10:31 AM
SoundVillageStudio SoundVillageStudio is offline
Default Core card PCI-X or Pcie Accel?
HI to everyones, i need a suggestion from most of you experts.
I'm owner of a HD1, with HD8 and a 96 I/O
I have broken the PCI-X Core card, and i'm looking to buy another one, finally i find it, but i'm asking:
1. Is better to change/update with an Accel pcie or i must continue with the PCI-X Core for sessions compatibility?
2. What change about the colours of PCI-X blu and PCI-X green cards?
3. Is the Accel PCIe the main (as the Core for PCI-X)?
I hope you reply sooner cause i'm billing on ebay
Thanks very much
Old 04-25-2017, 05:41 AM
suicune suicune is offline
Default Re: Core card PCI-X or Pcie Accel?
1) Your Pro Tools version and plugins are the only consideration regarding session compatibility not the hardware. I assume you realise you will need a newer mac in order to run PCIe. You didn't actually specify your current mac, I'm guessing from your PT version it is a G5? If you're looking at cheesegrater mac pros you need to check all your PPC plugins have intel versions and if you can still get versions of them that work with PT8 and your OS. Bear in mind that for the vast majority of plugins if you simply upgrade to the latest version it will NOT work with PT 8 TDM as the latest versions will be 64 bit AAX.
2) I think the blue and green cards are just different years of manufacture and aren't different in terms of functionality. But please don't hold me to that one as I didn't go HD until PCIe generation, hopefully another expert will chip in there. I know I have one blue and one green Accel PCIe card myself and they both work the same.
3) No Accel Core PCIe is the primary card. Accel PCIe are the secondary cards.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Old 04-25-2017, 12:25 PM
s.d. finley s.d. finley is offline
If your mac is PCIX then its a good idea to stick with that. Need a PCIX expansion chassis? I have one I can sell. You could stick 6 cards in that sucker for pretty cheap.
sdf
www.sugarhillstudios713.com
Old 04-26-2017, 09:37 AM
JFreak's Avatar
JFreak JFreak is offline
Blue (newer) and green (older) cards are both valid production items. RED CARD however is a prototype.
Janne
Old 05-02-2017, 07:05 AM
Thanks for your faster reply. Cheers to everyone.
PT HD1 (core card PCI) x PTHD1(Accel core card PCIE) Alécio Costa Pro Tools TDM Systems (Mac) 6 05-02-2017 06:52 AM
Digidesign HD3 Accel PCIe Core + 2 accel cards & 192 w/8 channel d/a output card juneaudio Buy & Sell 3 02-25-2015 12:45 PM
accel core card pcie pie55 Pro Tools TDM Systems (Mac) 1 06-16-2013 09:53 PM
FS: HD2 Core+Accel Card PCIe Meads Buy & Sell 24 12-30-2012 05:59 AM
FS: HD1 Accel Core PCIe card Captain Audio Buy & Sell 0 05-15-2012 10:19 AM
