#31
Re: AFL/PFL not working since updated to PT12
thx for replying. I guess you are not using a D-Command and a xMon? Problem is, it should work if set correct in the I/O Setup. My Main path is set to HD I/O Out1-2 and the Cue path is set to 96 I/O Out1-2. The Cue Path should never get influenced by pressing Solo while in AFL/PFL as the xMon in combination regulates that. DigiTechSupport couldn't find the problem and also no one else at the DUC who's using a D-Command has the problem. As the D-Command has dedicated AFL/PFL switches, I would like to continue using those switches for changing from SPL to AFL. For me it would just be a workaround to use any other method than the one I was using before I updated to PT12. However, thx nevertheless :)
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Reason rewire not working in PT12 | andycopeman | Pro Tools 12 | 4 | 09-03-2018 05:38 AM |
Pro Tools FAQ is now updated for PT12, etc. | nst7 | Pro Tools 11 | 120 | 01-25-2015 01:08 PM |
Updated to Pro-Tools M-Powered 8. 7.3 stopped working! | radicalmachine | Pro Tools M-Powered (Mac) | 0 | 02-07-2011 03:38 PM |
updated to 8.04 and not protools isnt working properly please help!! | glowinthedark33 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-11-2010 06:19 PM |
8.03 cs1 LE Anyone updated? Keypad not working | [email protected] | ProControl, Control|24, Command|8 | 8 | 04-22-2010 01:26 PM |
