#21
Re: AFL/PFL not working since updated to PT12
Broadcast mode setting has gone as you now do it via the I/O monitor setting which is more flexible - if you set the AFL/PFL output setting to be your main speaker out it behaves as if Broadcast Mode was off, if you set the AFL/PFL output setting to be some other output than the main speakers the AFL gets split to that without disrupting the main speaker output - as if Broadcast Mode was On.
Pete |
#22
thx for your infos. This is what I did. But when I set the AFL/PFL output setting to be my MainSpeakerOut, then also XMON's Cue1 out gots overwritten by the AFL/PFL signal. This is the problem I am having ! I cannot listen AFL/PFL while an artist is singing/playing without interrupting his Cue1 signal which goes to the recording room and should remain untouched. Edit: If I am using PT 11.3.2 all is fine !
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
#23
That will happen if your Cue source is set to Main, it shouldn't (and doesn't happen here on my D-Control) if you set it to source from Cue input 1-3.
Cheers, Pete |
#24
Like I wrote, when I use PT11 all is fine, so I would say it is NOT a hardware failure.
#25
You got me beat then! It works as expected here, was just going through the usual ways it may not work, I'll have a think and a play.
Good luck, Pete |
#26
Sounds as if the X-Mon is still muting an output when engaging AFL/PFL. Try toggling that when you have PT11 launched. |
#27
Thx all for checking
#28
Probably another bug "in very care cases" ... ... ...
#29
another year is over and I still cannot get AFL/PFL to work like it used to work using PT11. Maybe any "new things" I could try ? Thx
#30
Here's an option that you might consider:
Since Pro Tools Solo kills not only all track main out, it also kills all post-fader sends, BUT a track mute does NOT mute Pre-fader sends(both of these traits make it unwise to solo anything while tracking talent), I came up with a method of "solo" that bypasses all of the above. Plus it allows me to "solo" AUX tracks without worry about muting/killing routing TO those AUX tracks. Here's how I do it. on ALL my tracks in session templates, and all my track presets, I fill the bottom send(send J, IIRC) with a Pre-fader send that is muted by default. Instead of hitting a SOLO button, I do a Ctrl-click on this send(or on as many as I want) and this AUX routes to a separate stereo output that shows up as an input option on my monitor/source controller(Presonus Central Station here, but most controllers can handle this). So, I can, in effect, "solo" anything, without affecting anything else in the session. It may seem a bit whacky, but if you have a spare set of analog outputs, it could be an effective solution, especially if its easy to access send mute state on your control surface
Reason rewire not working in PT12 | andycopeman | Pro Tools 12 | 4 | 09-03-2018 05:38 AM |
Pro Tools FAQ is now updated for PT12, etc. | nst7 | Pro Tools 11 | 120 | 01-25-2015 01:08 PM |
Updated to Pro-Tools M-Powered 8. 7.3 stopped working! | radicalmachine | Pro Tools M-Powered (Mac) | 0 | 02-07-2011 03:38 PM |
updated to 8.04 and not protools isnt working properly please help!! | glowinthedark33 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-11-2010 06:19 PM |
8.03 cs1 LE Anyone updated? Keypad not working | [email protected] | ProControl, Control|24, Command|8 | 8 | 04-22-2010 01:26 PM |
