pro tools export issues
I am a audio post engineer for TV. I'm working on a show at 29.97DF. There are international versions required and they want the audio at a frame rate of 50i, which I assume is 50fps. In my session setup, 50fps is listed in "Time Code 2" but, as I understand it, this is only an additional time display, not a change in tc rate.
How would I go about converting my 29.97DF audio to 50i audio for export? |
Re: pro tools export issues
50i is a video term. The corresponding audio timecode rate is 25fps, AKA PAL.
I am assuming you are working in Pro Tools since you are on the DUC. I would suggest that you output your NTSC (29.97DF) audio, and start a new session at 25FPS. Import the final audio from your show, select copy and select Apply SRC. Under the source sample rate pull down go to 48k pull up/down and select 50050 as your sampling rate. After the conversion you audio will be running at PAL speed. It will also be playing back a semi-tone higher in pitch. Randall |
Strike 1.5 Midi Export Issues | dreamslide720 | Virtual Instruments | 31 | 02-07-2013 01:04 PM |
Aaf export from Avid to pro tools @ 23.976 tc issues | paulmmoran | Post - Surround - Video | 2 | 06-07-2012 10:52 AM |
Track Export issues | Sturphy | macOS | 0 | 12-06-2011 06:36 PM |
.MID export issues | tonejunkee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-05-2008 05:24 PM |
6.2 TDM on XP - MP3 Export issues | Ken P | Pro Tools TDM Systems (Win) | 2 | 06-01-2005 09:32 AM |
