Retina MacBook & Eleven Rack?
Any one using a Retina MacBook & Eleven Rack? What's your system like? External drives? USB hubs? Etc?
Re: Retina MacBook & Eleven Rack?
Not sure what possible compatibility issues you might be thinking of here, unless you mean *ProTools* with the Retina MacBook.
There shouldn't be any problem. Other people have reported that PT10 works great on the Retina Macbook Pro, including HD systems (via Thunderbolt).
As for drives, you have a few options. You can get USB 3.0 drives, which work fine, or if you have existing firewire drives, you can use the $29 Apple Thunderbolt to firewire adapter with the Macbook's Thunderbolt ports, which also work fine. And USB 3.0 is backwards compatible with 2.0, so there shouldn't be an issue with plugging in the Eleven Rack. You will need to separately download the drivers for the Eleven Rack, but that's the case with all interfaces with PT10. |
I was trying to do some voiceover work with the mic input of the 11r the other day and I couldn't record for more than a few minutes without pro tools or studio one reporting an error (something along the lines of cpu overload if I remember right).
Even when I'm just playing guitar with pro tools open, the audio will 'hiccup' or digitally skip, like it lost it's clock or something. It's way worse when plugged in directly to the usb 3.0 port of the 15" retina mbp, running through a Belkin USB 2.0 hub first seems to lessen the dropouts / spikes / skips somewhat, but it's still bad. I don't know what to try to make it work as reliably as my old 003 did via firewire. It seems the core audio drivers for the 11r are not able to handle as much as the digi drivers for the 003. So my current solution? I bought an Apollo Quad Thunderbolt interface and am going to just go spdif out of the 11r into the Apollo. I think you loose the ability to embed the 11r settings to the track that way, but hell, I can't use it at all currently. |
What Pro Tools and OS X version are you running? What audio disk drive (make/model/spec/interface) are you recording to? Just recording the wet guitar track? How many other tracks? Any plugins? Any VIs? What playback engine settings are you using? All the properties in the playback engine dialog panel would be great. You are not trying to use an aggregate IO audio device right? And the Eleven Rack is not a part of an aggregate device and/or also set say as the system sound device? And have you carefully checked all the Pro Tools systems optimizations for OS X have been done (seriously double check them -- e.g. I've found spotlight turned back on on more than one occasion when I was *sure* I had turned it off.). Even if USB3 is a problem here, these other things may make it worse. Darryl |
I'm using a MacBook Pro (the model just below the retina) with Logic Pro and a Focusrite Pro40 interface connected via FireWire to the Thunderbolt port with an adaptor. The 11r connects to the Pro40 via SPDIF. It all works great with no latency. I also have a Lexicon 300 which has optical in/outs that also connects to the Pro40 digitally.
Fritz
MacMini with 16GB ram Mac OS X 10.10.5 Logic Pro X Seagate 500GB GoFlex Pro 7200rpm Firewire 800 Ultra Portable Drive Audient iD22 and Focusrite Pro 40 Interfaces Focusrite Red 3 compressor Lexicon 300 Digidesign Eleven Rack Waves Gold Bundle • CLA Classic Compressors • Slate FG-X, VBC, VCC, VTM Slate Trigger EX • Superior Drummer 2.0 |
Darryl |
Fritz
Trying to understand how well the standard Pro Tools and Eleven Rack setup works at all for folks looking at moving to Macs with USB3. Darryl |
Fritz
MacBook Pro Not Recognizing Eleven Rack | Archalen | Getting Started | 11 | 01-19-2014 07:00 PM |
Regular Macbook Pro vs. Macbook Pro with Retina display | pzykt | macOS | 9 | 04-02-2013 08:32 AM |
Experiences running Eleven Rack with a USB3 MacBook Pro or MacBook Pro Retina? | Darryl Ramm | Eleven Rack | 3 | 09-18-2012 11:22 PM |
Pro Tools Instalation Failure (macbook pro/eleven rack) | danbro2012 | Eleven Rack | 1 | 06-23-2012 11:12 PM |
Pro Tools Instalation Failure (macbook pro/eleven rack) | danbro2012 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-23-2012 07:15 PM |
