(-5000)
When trying to access an insert I received the following message:
Thanks! CJ |
Re: (-5000)
Check the permissions on the plug-in file that you were trying to load.
Re: (-5000)
yes. it was a permissions issue, but what I don't understand is the why.
i always make a dedicated account for Pro Tools and give administrative rights. do you know why that is not enough? thanks! cj |
Re: (-5000)
That would depend on what the permissions were and what you changed them to.
Administrative and Read & Write, of course!
cjt MacBook Pro (17-inch, Early 2011) Processor 2.3 GHz Intel Core i7 Memory 8 GB 1333 MHz DDR3 macOS HighSierra Version 10.13.6 Pro Tools 2018.12 |
Re: (-5000)
Can I join this one please? Just upgraded Pro tools 8 MP to Pro-Tools 10 - and new iMac 2.8 GHz i7. Cannot use Pro tools at all > You do not have appropriate access privileges (-5000) while creating "IO Settings"
The permissions on protools application itself and 'Read/Write' Alarmed to find no formal support provided by Avid having just bought an expensive upgrade! Any help gratefully received Peter |
Re: (-5000)
so after you setup the permissions for the hard drive and click the gear to apply to all.....you still have no permissions to change the i/o??????
I just migrated from WIN and I had the same permissions problems but after changing the hard drive and clicking the gear the errors are no longer a problem...
Cameleon 5000 | Stig Eliassen | Virtual Instruments | 0 | 09-11-2007 03:06 PM |
-5000 | groovilator | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-22-2006 11:36 PM |
Error 5000 | poppy | Pro Tools TDM Systems (Mac) | 2 | 07-23-2004 04:14 PM |
Help with Error 5000 with M-box PT6.1.1 Le | M-boxNewbie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-23-2003 02:13 PM |
I HAVE $5000 and already own a g4. | pixelrider | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-27-2003 04:42 PM |
