  #21
Old 02-06-2012, 11:49 AM
Gonk Gonk is offline
Default Re: 24 or 32 bit float
Originally Posted by WernerF View Post
You can only restore a 32 bit file to an undistorted waveform with clip gain. It is not possible to do this with a 24 bit file. Clip gain can make the 24 bit file lower in level but the waveform will still be clipped if it was clipped in the first place.
Thank you, exactly.
"Are you sure what side of the glass you are on?"
www.facebook.com/thereapersofficial
  #22
Old 02-06-2012, 01:53 PM
roberts roberts is offline
use 32 bit and go back to work - stop worrying about if the winds is blowing from the west or northwest.
  #23
Old 02-06-2012, 08:08 PM
janmuths janmuths is offline
Well, doesn't that depend on where the clipping occurs? In the converter or when processing in Pro Tools (post converter)?
2010 Dolphin Award for Production / Engineering
AVID Certified Instructor
  #24
Old 02-06-2012, 08:18 PM
Try it.
Just did. Created a 32-bit float session, plugged in a mic, gained up. Converter clipping cannot be undone by bringing dow clip gain.
Would have put my whole perception of reality in a question if it did.
J.
  #25
Old 02-07-2012, 05:46 AM
daeron80 daeron80 is offline
Sorry, I thought you were talking about converter clipping.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
  #26
Old 02-08-2012, 03:05 PM
My bad... silly mistake, only recently changed to 10 and the waveform was "expanded" too much, set it back to default and noticed it never did run over.
I thought it was odd at the time and should have known better (I know that 24 bit isn't even 24, it's 21 bit really) so how could I get a distorted waveform without clipping the input pre/converter in 32 bit, Drunk Avid's Kool-aid there.
If there are mixing benefits then I'm all for 32 bit, Will be interesting to get 2 of the same session one 24 and one 32 bit and see the benefits of processing and how far beyond 24 bit 32 can go, am interested to see/hear that test.
  #27
Old 03-13-2018, 06:41 AM
notable's Avatar
notable notable is offline
My students, who don't know good gain staging yet, benifit from 32bit float. Last year one student forgot to turn up a Pre-amp on a tom mic. Looked like a flat line till clip based gain to max and gain plug added in another 20 something dB and voila. 40-50dB of mic Pre gain created in Pro Tools. This yielded a Tom track with out background noise. Is this great engineering? NO. Is this useful? Absolutely. So all the engineers who are saying you don't need 32bit float with proper gain structure if you aren't doing a fair amount of clip gain or radical gain structure may be right for talented and experienced recording engineers.... but if you are a newbie, this can be a another helpful tool.
Notable.com
AfricanUnderground.com
DemocracyinDakar.com
NomadicWax.com
32 Bit Float boogiemotel macOS 76 01-20-2013 09:28 PM
32 Bit Float boogiemotel Pro Tools 10 28 01-09-2013 10:22 AM
new recorders run 24 bit vs 32 bit float rockguitarist1255 Pro Tools 10 1 01-07-2012 10:06 PM
32 bit Float Logichead Pro Tools 10 0 10-22-2011 11:08 AM
Help! What is a 32-bit Float Mix ????? Rhapsody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-27-2010 09:46 AM
