Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 09-02-2011, 02:06 AM
Default Re: Strike: Part Retrigger
Thank you for posting that information. The problem is the frequency at which the bug occurs following the step to reproduce and personally I'd rate that at about 35% frequency. I suggest you post the session file and Strike Plug-In Setting file when you encounter the problem again. See, I have sessions that do do what you are talking about but there are more sessions that don't. As I posted, the flaming is a by-product of setting Part Retrigger On. It is strongly recommended that this setting be switched Off under the circumstances in which you are using Strike. The Strike Plug-In Guide states too that you use Part Retrigger in combination with Groove Change Grid. Try a 1/4 Note Groove Change Grid setting. Given the frequency of this bug, it's no wonder it's been around since 2008 but if you can post those files next time, it'll help towards getting a fix.
Aaron Mulqueen - 001 HD Native
Strike: flams on 1 when Pattern Retrigger is on? synthetik42 Virtual Instruments 4 03-28-2009 01:00 PM
Strike Part 2 Now Available RussUK Pro Tools TDM Systems (Mac) 0 01-06-2009 03:27 PM
Strike Part 2 Now Available RussUK Pro Tools M-Powered (Mac) 0 01-06-2009 03:26 PM
Strike Part 2 Now Available RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-06-2009 03:25 PM
Strike Part 2 Now Available RussUK Virtual Instruments 0 01-06-2009 03:23 PM
