Old 01-26-2010, 08:10 AM
cheeseandpepper cheeseandpepper is offline
Default Bug? - Clicking in edit window selects everything
Hi
Since updating to 8.03 LE I've noticed some strange intermittent behavior. Seems like sometimes when I click anywhere on any track in the edit window the entire session gets highlighted. It's similar to what I'd expect when I have the "All Group" selected, but I cant highlight portions, it just automatically selects everything. Then I click on the tempo or meter area and it all gets unselected.
I can't really replicate this on command, but it's happened quite a few times, most often upon first opening a session.
Anyone else experiencing this?
2.8 Ghz (8-Core) Mac Pro
8 Gigs Ram
PTLE 8.0
Old 01-26-2010, 08:14 AM
Tim Let Tim Let is offline
Default Re: Bug? - Clicking in edit window selects everything
I have also noticed this since I upgraded to 8.0.1. This along with the click/erase midi note issues drives me crazy as well. When clicking once in a specific area it highlights the whole track or whole session.
Old 01-26-2010, 09:22 AM
bfx bfx is offline
+1
had to restart PT to get it working again. will try clicking tempo/meter, see if that helps. pretty anoying once it happened. noticed it since 8.0.3, but could have happend in 8.0.1 as well, don't remember...
Mac Pro 8-core 2.26 | 6 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8
MacBook Pro i5 2.3 | 4 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8
Old 01-26-2010, 10:16 AM
oliarnalds oliarnalds is offline
Originally Posted by bfx View Post
+1
should be enough only to restart the session...
yes, i have the same problem as well.. obviously :)
Old 01-26-2010, 10:28 AM
stustan stustan is offline
I have experienced the exact problem on a daily basis, reload session is my only workaround
Old 01-28-2010, 08:59 AM
bfx bfx is offline
That works for me, no more restarting/reloading necessary. Thanks for the tip, cheeseandpepper!
Old 01-28-2010, 11:05 AM
allstaar's Avatar
allstaar allstaar is offline
Yes, I've been having this too.
Zooming out gets rid of it for me.
Old 04-07-2011, 11:52 AM
claybot claybot is offline
I get this too. I'm on 8.0.4. usually I have smart tool selected. I switch to grabber and click around in the edit window. eventually it goes away. but annoying and it happens enough to affect work flow.
Mac Pro 8-core 2.26, 10.7.5, 002R BLA sig mod, PTLE 10.3.2
Old 07-17-2012, 04:54 AM
Bartonnen Bartonnen is offline
I have the same problem. Clicking anywhere doesn't solve it for me and restarting doesn't help as well.. It's a huge interruption of workflow for me, please help! :)
I use Protools LE8 Version 8.0.3 on a windows 7 32bit version.
Old 07-17-2012, 05:11 AM
bfx bfx is offline
Try updating. See cylabot's post who used a newer version of PT 8. I remember the issue more or less got manageable by clicking somewhere in the timeline or in the arrangement in a later version of PT8, as well.
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
Memory location edit without clicking? Bob L 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-23-2011 10:24 AM
Clicking selects all? sysyphus300021 Pro Tools TDM Systems (Mac) 5 06-16-2010 08:34 AM
Playback interrupts when clicking on edit window. pcmusicpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-04-2009 10:15 AM
Clicking in Edit window does not move playback marker...help! Lofty11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-28-2009 09:01 PM
