Old 04-23-2009, 04:41 PM
KPCC KPCC is offline
Default Launch PT from a Command Line
Hi all, Can a PT session be launched with session data via the command line? If so what is the correct syntax? Thank you for your help. Jeff Krinock, KPCC.
Old 04-23-2009, 04:55 PM
JMS40 JMS40 is offline
Default Re: Launch PT from a Command Line
I had no problem doing that by entering in the full path to the session file.
Example:
D:\test\test.pts
Entering that command line executes Pro Tools and opens the session.
Scratching my head trying to figure out why in the world you'd want/need to do this though...
Old 04-23-2009, 05:14 PM
Thanks JMS40.
I was hoping a new session could be created from the command line so our reporters wouldn't need to use the PT interface to create a new session.
We have multiple studios and currently most of our reporters have various versions of the same story on multiple computers, depending on where they could initially access a studio. I am trying to write a small program that will move a PT session from the network drive to the local machine, launch PT, then move everything back once PT has closed.
Control Pro Tools from the command line bjorn Pro Tools 10 12 07-15-2013 02:57 PM
protools 10 clip gain line /volume line alidav Pro Tools 10 3 03-09-2013 05:21 PM
Clip Gain Line on D-Command? Borgbilly ICON & C|24 5 09-13-2012 09:43 AM
Could not complete the Disk Allocation command line 89 matt2083 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-07-2009 08:37 PM
command 8 off line/help redchair ProControl, Control|24, Command|8 3 07-21-2006 11:47 AM
