Sync I/O delays
i recorded sound on Beta SP than moved the project to another studio. This studio has HD 3 on G5 2.0 with sync I/O. Beta recorder is the same. When i align the same project to the same beta i have 2 frames difference. Sound on Beta is later. In stop TC on Beta and PT is perfectly the same. I tried both tc from Beta and via 9pin. No offset in session setup am i missing something? thanks Leonid |
Re: Sync I/O delays
Been a while since I worked with SP, but could monitoring with the CONFI head create the offset? Just throwing out my first (and only) thought....
Colin Van Hattem Noizemaker Productions |
Re: Sync I/O delays
no way. It,s 1800 it doesn't have confi ...
Re: Sync I/O delays
Did you check the machine control profile to make sure that there wasn't an offset? That burned me once.
-Richard
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5 www.TakomaMedia.com |
Re: Sync I/O delays
2 frames? sounds like a black burst termination problem.
Re: Sync I/O delays
Where i can find offset in Machine control profile? In session setup window there is no offset
i tried with blackburst, with internal- same result. I do not have a drift. It definitely looks like offset while playing. |
Re: Sync I/O delays
Is the Video reference on the machine terminated? There should be a switch
under the B&C input. I think it says 75 ohms. I had a similar problem when a short lived assistant tried to hook their camcorder up to my Beat SP machine and didn't bother to test it before my session the next day. |
Re: Sync I/O delays
There is also the "External Time Code offset" menu also under setup. Check there too. -Richard
MTC Sync Fails With Higher Plugin Delays | Trailerman | Pro Tools 11 | 19 | 01-17-2014 11:55 AM |
PT 8.3 - digirack delays + tempo sync | alex s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-17-2009 03:02 AM |
How To Make Regions Sync Without Delays?????? | popedcollarpro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-11-2007 08:50 PM |
Sampletank 2.1 delays won't sync. | scottedog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-02-2006 07:34 PM |
long sync delays in OSX | Syncman | Post - Surround - Video | 2 | 11-22-2003 11:51 AM |
