#21
Re: D-command frustrations, anyone else?
I did notice that the Groups hold this flip, so when you switch to another group that isn't flipped and come back to the flipped group, they are still flipped. Make sense?? Not sure if this is good or not yet. Wow, it's another world with this thing!!! |
#22
Only downside, - can be tricky tho, - because you cant see the name of the channels at the same time so you have to remember where is what.. |
#23
Hi dmazurek,
Thanks for the tip. Though the workaroud will surely get me the faders grouped and on the surface in a similar fashion, I am trying to do as little button pressing as possible. For my work flow, the custom groups would be 6 page scrolls through the groups page to get the one I want. It's just not practical at all. Is there a way to make a short cut to just THAT group? Thanks. mike |
#24
no shortcut but.......
the last group selected, stays selected, which helps. Besides, even with Custom Groups, you be doing some paging since it works the same way, enter Custom Groups, and use the soft keys to select which group. And you only get 8 of them on the D Command, whereas with mix groups you got lots. Not perfect but it's working for me at least. |
#25
Can't you do this on a pro control? It seems so basic.
#26
Cool & Informative Video Tutorials from Groove3 |
#27
No PCs had it. It's just that it was terrible with nasty clicky knobs. I never used it.
#28
I use the PC plugin editing all the time. I hit EQ on the channel, and change the EQ. I hit DYN, and change the dynamics. It's very easy, and very basic, and that the Icon can't get it together to have this is somewhat baffling.
Granted, the DSP editing section on the Icon is so much better, but it sort of proves my point even more. It's typical Digidesign. They carry the ball to the 10 yard line and then drop it. |
#29
The complaint to this point is that there appears to be no way of "focussing" a channel by selecting a plugin from the actual strip it's on. Judging from Gil's responses, this is an oversight with a fix possibly immenent.
#30
Client Frustrations | brownj24 | General Discussion | 9 | 04-15-2007 09:07 PM |
PT 6.4.1 TDM frustrations continue | Joel Cage | Pro Tools TDM Systems (Mac) | 3 | 12-15-2005 01:12 PM |
Version 6.4.1 TDM Frustrations | Joel Cage | Pro Tools TDM Systems (Mac) | 4 | 12-14-2005 04:50 PM |
410 Frustrations | deluxemusiker | Pro Tools M-Powered (Mac) | 3 | 08-10-2005 10:46 PM |
Help me w/ my frustrations | Da Cryptic One | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-22-2000 07:16 PM |
