Bizarre behavior on D-Control
This isn't necessarily the D-Control's fault but is totally weird and it might be implicated.
(1) Twice now on two different sessions, I CANNOT solo safe any tracks. If I try and do it from D-Control (command and a solo button) the track simply goes into normal solo. If I try and do it from the QWERTY keyboard ... wow! ... a little mini fader jumps up over the solo button. It looks like a send fader. If I slide the trackball up or down while holding command ... get this ... the AFL/PFL pot on the D-Control increments/decrements along with it. So, commmand clicking solo creates a mini fader and that fader adjusts the AFLPFL level on the console. Yup, OK!! <g> This is with any solo button across the whole session. I sent that session home to my M-Powered system and it was fine there. (2) Today for a short time only, there was a track that would also solo with any other track that got solo'd. NO, this track wasn't in any sort of group. Even with groups suspended, no matter what I solo'd on the session, this one other track would also go into solo. I kept working and eventually it stopped happening. No idea what caused it. Anyone else seen anything like this? Gremlins or what!! <g>
Cool & Informative Video Tutorials from Groove3 |
Re: Bizarre behavior on D-Control
Hi Mikey,
You must be in AFL solo mode on the d control. Switch back to SIP and you will be able to solo safe. Also, check to see that you are not in solo latch mode for the other issue you're seeing. Hope this helps, Jamie |
Hi Jamie,
Great call on the AFL/PFL - that's absolutely the problem. So I guess the little fader pops up to act like a stop sign to warn you. I should have worked that out! As to the track the kept solo'ing, I haven't seen that since so I'll chalk it up to "weird" and see if it ever happens again.
Edit window - right/left arrow keys - bizarre behavior | Londoner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-05-2010 05:47 AM |
Akai MPD26 creating some really bizarre PT click behavior | Jonny Jon Jon | MIDI | 0 | 05-07-2010 12:48 PM |
Digi hardware - bizarre behavior - Digi you will lose this market share | andre67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 02-26-2010 07:45 PM |
PTHD for Windows -- bizarre Edit Window behavior | jjnyc | Pro Tools TDM Systems (Win) | 4 | 12-09-2007 06:53 PM |
Bizarre Premiere 4.2 Behavior | JKD99 | Post - Surround - Video | 8 | 02-20-2004 09:27 AM |
