rosetta w/ 888 question
I've heard the clock in the apogee is more accurate than the 888 and can drive the PT clock for better sound. Curantly I'm linking with usb only. Do I need word clock for this idea to work. Can it truly sound better? thanx
Re: rosetta w/ 888 question
the Rosetta probably has way lower jitter spec's then the 888's (16bits or 24 ???).
linking with usb.....eeerrrrrrr, don't get that one quite.......anyhow, , supposing you use the rosetta to AD, and then go digitaly, AES/EBU I suppose to the 888, you need to choose one as the master and the other one as slave (as all the rest of digital periph's for that matter). Anyhow......my guess, the rosetta having the best jitter spec's, use it as the clock master. since I don't think the rosetta offers this superclock x256 thing over BNC, you'll have to do it with aes/ebu. connect aes output rosetta to aes input 1/2 on the 888 (has to be 1/2). set the rossetta on internal clock and in PT, hardware setup, set the 888 to digital input 1/2 and sync to digital. That should about do it. Can it truly sound better. YES !!!!!......try it.......if you want to know the why and how.......check this one...... http://www.digido.com/ you will find an article on jitter by Bob Katz. I had to read it 25 times to understand half of it but........ Hell, it's 07.30 in the morning and I got to bed at 02.00......Damn the construction workers next door..........had nothing else to do..........someone correct me here if I'm wrong. ------------------ Chris Lambrechts
Chris Lambrechts Applications Specialist- Live Sound |
mmmmmm, reading it again made me think of something......what's the use.....since the rosetta does only AD and jitter influences are also or even more important on DA !!!!!!!.......Digi......HELP..........guess I got stuck in my own explanation.........someone HELP,......Bob Katz.........??????????anybody.
------------------ Chris Lambrechts [This message has been edited by Chris Lambrechts (edited September 08, 2000).]
"linking with usb.....eeerrrrrrr, don't get that one quite. "
Sorry Chris, I ment AES/EBU and was wondering if that alone will do the trick or if I should be linking with word clock as well? I'm thinking it must be the same but this hole word clock thing is mistireous as you seem to have found out. I would think that even though the rosetta only does a/d, as long as PT stayes locked you'd still get the benefits during d/a. I dont have time to read this guys aritcle 25 times, but thanx for doing the research and sorry about the 5 hours sleep. |
A short trip to the Apogee site would not go amiss. They have documents on almost everything you could think off.
Failing that ask Roger at Apogee tech [email protected] www.apogeedigital.com Jules |
Rosetta 200 with HD question. | kalab | Pro Tools TDM Systems (Mac) | 3 | 07-28-2010 07:52 PM |
Rosetta 200 question | kastadyne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-23-2007 08:03 AM |
rosetta 800 or 192 io ??? the big question | blumediaprojekt | Pro Tools TDM Systems (Mac) | 4 | 12-25-2005 04:07 PM |
001 Rosetta question | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-09-2004 02:57 PM |
rosetta question | mbuono | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-29-2003 04:34 PM |
