digi coreaudio manager
I have not seen this happen before, but after i switched my mac on this morning I logged into Microsoft Entourage for my email and instantly this triggered the Digidesign Core Audio Manager to switch on. When i Quit the email the CoreAudio manager also quit. So i tried it again, and it seems that it is activated by the email software.
Is this normal behaviour? I'm just concerned because it has not happened before. I'm using 10.3.8 and the latest version of PT (6.9 cs1) but the PT was not on at the time. regards adam
adam taylor video editor/dubbing editor/sound design/motion graphics/compositor United Kingdom |
Re: digi coreaudio manager
Interesting. I'm running 6.9cs1 on MacOSX10.3.8 and have had a problem with my Mac since Thursday. (I am doing a fresh install of OSX and Pro Tools as I write.) I suspected the Core Audio had something to do with it. The funny thing is my mail and internet has been a mess as well. This has never happened before.
hi,
perhaps it´ll change behavior if you uncheck audiosignals in your ms-email-app-preferences... not sure, but i´d give it a try. greets
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD |
i think the problem is because yesterday i used the protools hardware to listen to itunes and set the audio midi settings to use the 192 as the system audio output. It seems that unless you switch it back to built-in then when you open a programme that could use sound it will grab the interface for itself and trigger the CoreAudio Manager software.
Any chance we can get an "opt in" function back for the core audio driver? There's only a couple of apps I want to play through my digi hardware, the rest is just a pain in the arse. I know you can shift click to launch an app and bypass the core audio driver, but that's still a pain. What happened to only choosing the apps you wanted to come through the digi hardware and being able to open and close any program at will?
Cheers, Iain
myspace . com / iain _ graham |
We had so many complaints about having to 'opt in' that we removed the capability, instead giving the 'hold shift' option.
Dammit! Preferance?
Cheers anyway, Iain
I liked the opt-in much more, too. I seem to always miss the Shift-key and then have to wait for the driver to load/init/...
Of course a real multi-client (TDM and Core Audio at the same time) driver would be best... ;-) Peter
http://www.merlinsound.de |
Digi CoreAudio Manager | phatjones | Pro Tools TDM Systems (Mac) | 3 | 04-09-2008 02:35 AM |
Digi 002 Coreaudio Manager | Samuel_Wire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-22-2007 08:50 AM |
what is Digi CoreAudio Manager ? | larryfine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-17-2007 01:38 PM |
Mbox 2 Pro not seen by "Digi CoreAudio Manager" | Curtis Marolt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-15-2007 12:11 PM |
Digi CoreAudio Manager 7.3 ? | sctstudios | Pro Tools TDM Systems (Mac) | 1 | 01-06-2007 12:39 PM |
