backwards tracks
HI All
I'm looking to find an answer on either recording backwards tracks or taking some tracks and turning them backwards. I've looked high and low through the duc and cannot seem to find answers. Also looked through the manuals. Has anybody done this with LE before? thanks |
Re: backwards tracks
You do it in Audio suite. Select the region or portion of region and process using reverse. For real fun , verb the heck out it, turn it around again. Fun for days
Brian
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers |
Select the track or portion of a track you want to reverse. Click on the Audio Suite tab at the top of your screen and find the "Reverse" plugin. Voila.
Kyle
I've seen a million faces, and I've rocked them all. |
I've been using the Reverse plugin for years. Whenever you need something crazy, just select a random region of audio and reverse it. What I'd like to know is, is there any way to set Pro Tools to record backwards, in the same way that you can record at half speed? Tim. |
Yes there is a way to record backwards and it's the only way to do it.
By singing or speaking backwards. Sorry I couldn't resist!!! David |
?dne eht ta gnitrats gnos eht gniyalp yrt ton yhW
,tseB egdiR eulB
New (January 2016): MacBook Pro i7, 1TB SSD OSX 10.9.5 Glyph 1tb External HD 7200 002, Mbox Mini (both still working on OSX 10.9.5) (Mbox records well, static on playback. Output works through MBP headphone jack) External Acer 23" Screen Still waiting to choose and to install PT 10-11-12 Old system (still running): Mac G5 Dual 2.0, 5.5 gig memory 160 (main) & 80 (audio) gig internal hd's OSX 10.4.11 PTLE 7.1,CS10, 002 Console Reason 3.0, Live 5.2.2 |
Gordon in Austin Mac G4 Digital Audio 466MHz MacOS 9.2, 1.25GB RAM, 110GB HD digi 001, PT LE 5.3 |
No, it's not a joke... just think about it for a second. You select a point in the song where you want to record from and instead of recording forward (ie red shading moving from left to right) it moves backwards (ie red shading moves from right to left). The benefit of this is that you could record, for example, a guitar solo, and while you're playing you would be able to hear musical components in the pre-recorded tracks (albeit backwards) that would give you a greater sense of where you are in the song. Because there is no reverse recording in Pro Tools (and I'm sure there isn't, I just thought I'd put the idea out there) you have to play along with the backing track like you would normally. This means that any changes in tempo/key/etc. will cause the solo to sound out of time or tune when it is reversed later using the Audiosuite plugin.
And before you say "that's impossible!", consider this. You can scrub/shuttle backwards and hear pre-recorded tracks in reverse, so Pro Tools is obviously capable of reading audio backwards, surely it's just as simple for it to record backwards. Recording in reverse has been around in analogue recordings since the 60's... why would it be considered "a joke" to have this implemented into digital recording. Are you an amateur who doesn't really have a clue, or are you just an [bleep]? Tim. |
I can believe I got bleeped for saying "[bleep]"!
I think backwards and reverse recording is being confused here. Certainly "reverse recording" has been practized as long as you have had reel-to-reel tape, simply by swopping the reels around. But what happens is just that you play back what you already have recorded backwards, but you are still recording your new track forwards, in reverse as it were.
I don't see how you could ever record the end of a phrase, whether it be backwards or just plain oldfashioned forwards, before you actually get to say or play it, no matter what. Cheers lnl |
7.4 HD and LE backwards compatiblity?? | real_eyes | Pro Tools TDM Systems (Mac) | 1 | 04-01-2008 07:15 PM |
backwards EQ?? | garret | Post - Surround - Video | 13 | 11-18-2005 12:37 AM |
Re:Backwards compatibility | penrithmatt | Pro Tools TDM Systems (Mac) | 3 | 06-25-2004 02:50 AM |
Prtools 5.1 backwards comp (stereo tracks) | Mike Thornton | Pro Tools TDM Systems (Mac) | 1 | 02-17-2001 04:34 AM |
moving all tracks backwards? | Dr. J | Tips & Tricks | 9 | 11-16-2000 11:45 AM |
