Old 05-06-2012, 05:16 PM
Swurveman Swurveman is offline
Default Artist Control v2 -PC with 1 ethernet port
Hello,
I just bought an Avid Artist Control v2 for my Windows 7 54 bit PC running Cubase 6 64 bit. I currently have 1 ethernet port on my PC, which I am using for an internet connection. If I buy an ethernet PCI card for my Artist Control connection, would I have any conflicts or problems. Does it matter (on my PC) if the Artist Control is on a particular ethernet port?
Or, is there a better solution when dealing with a PC with one ethernet port, like a Netgear 5 port ethernet switch, which would give me options down the road if I want to add a Artist Mix Control?
Thanks for your help/experience. Can't find anything in the manual dealing with a PC with one ethernet port.
Old 05-06-2012, 07:31 PM
chris-euphonix chris-euphonix is offline
Default Re: Artist Control v2 -PC with 1 ethernet port
If your Internet connection is via a router with multiple "LAN" ports, then simply plug the Artist unit into a spare one.
Otherwise you'll need a switch and/or a 2nd ethernet card.
Old 05-07-2012, 02:22 PM
Thanks Chris!
USB Ethernet vs. Artist Series mu-tron-kid Artist Series 1 02-25-2014 04:55 PM
Custom Ethernet Cable for Artist Control and Mix? TeamContra Artist Series 5 01-17-2014 07:56 AM
Artist Control / Ethernet Connection and Noise Problems lberrios1962 Artist Series 8 05-04-2012 08:20 AM
MC Control Ethernet port issue RuffinMedia Artist Series 2 02-03-2011 04:44 PM
Enable Ethernet Port For Pro Control? RT60 Pro Tools TDM Systems (Mac) 6 10-26-2007 03:32 PM
