Old 06-28-2017, 03:42 PM
MJP MJP is offline
Default Unable To Save [solved]
Getting this error message:
Could not save "" because Invalid argument (22) while opening "zvrpZRFWpxzxSQMX".
Last time I was able to save was before I did a 'fade to end' on one of the tracks.
Anyone know a solution to this and/or tell me why it happens?
Thanks,
Mark.
Old 06-28-2017, 06:29 PM
MJP MJP is offline
Default Re: Unable To Save
When all else fails, and there's no good reason for the fault, shut down everything and restart. That cleared the issue, but I'd like to know why the problem occurred. Anyone??
Old 06-29-2017, 05:41 AM
SoundByLaura SoundByLaura is offline
You could try quitting Pro Tools, going to the session folder and deleting all the fades, then re-opening the session. PT should re-build all the fades, and maybe getting rid of that particular fade file will help?
iMac 27"; 4.0Ghz Intel Core i7; 16GB RAM; Pro Tools 2019.12
Old 07-05-2017, 10:40 AM
MJP MJP is offline
Thanks for the suggestion. Deleting prefs and fades worked.
Old 02-02-2019, 03:47 PM
Nilreb Nilreb is offline
Default Re: Unable To Save [solved]
I have the same issue but I've done a ton of micro edits I'd ate to lose- and the last session backup is from about 30 min ago so I would lose them if I quit. Anything I can do in real time to save it?
Old 02-02-2019, 03:49 PM
PT 12.4 on a MBP 10.12
Can't save plug-in settings to root folder [SOLVED] Tobias Eichelberg Pro Tools 11 3 10-20-2015 02:18 AM
Unable to re-download PT10 to Mac OS X 10.8.4 [solved] Bodhisan Pro Tools 10 3 06-11-2013 03:09 AM
Unable to name disk file [solved] ronoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-16-2012 08:07 AM
Unable to save? Kermitmacfly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-15-2007 08:25 PM
Unable to save oneblood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-02-2005 09:59 PM
