MIDI track routing to Aux track quick question
Hi, I'm trying to get a MIDI track to playback audio via an Aux track as its supposed to for my Fantom X8. I set the MIDI input and output in the MIDI track channel strips to my Fantom X8 no problem. My problem lies in the Aux track. When I go to select the input on the Aux track, it does not show me any selections that would match the Fantom X8? I can choose from buses and just the normal audio inputs like mono 1, mono 2, etc. Am I missing a simple step here in routing this MIDI track correctly?
Thanks for the help
(PT12.4- Win7Pro - mboxpro3 -Axiom25- Maschine) |
Re: MIDI track routing to Aux track quick question
My Fantom X8 audio outputs are inputed in my Digirack 002 Input 1 and Input 2. Guide me through please if you can. Thx
I just did.
Done.
Is anything else required spkguitar in order to ensure when I play back my recorded midi track that the sound plays? I will of course do all of my music on the Fantom X8 using the performance mode which utilizes all 16 of the midi tracks to ensure the sounds play as well. Is Middam and the middev files for the Fantom X8 absolutely necessary to here sounds through all of the patches or will the X8 still be able to handle all of that without it in performance mode? Damn Midi setup is a bit tricky till I figure this out. Thanks and I appreciate the help
spkguitar: What would be perfect is if you could send me the steps to get all of this working correctly, from setting up from the Midi Studio in PT, to if Midi Thru needs to be set or not, etc. My setup is pretty straight forward: Digi002 and Fantom X8. The Midi connections are as follows
Fantom X8 - Midi Out to Midi in 002 then Midi Out 002 to Midi in Fantom X8 The Fantom X8 is connected to inputs 1 and 2 on the 002 I have studio monitors on the normal TRS outputs on the 002 Thanks again spkguitar...you are the man
Why are you using an aux tr?
Im not quite sure whwt you trying to do but if you have everything set up right,all you should have to do is arm the track play the instrument ....bingo=sound brandy |
Brandy, all I'm trying to do is record MIDI from my Roland Fantom X8 keyboard to Pro Tools (which I can easily do) and then have Pro Tools play the recorded MIDI audio back so I can hear it (currently the part I am having trouble with). Normally with a MIDI track, you must route it to an Aux track so you can hear the sounds you have recorded during playback. This is the part I am stuck on.
Brandy, with an Instrument track, I am not 100% sure if what I'm trying to do can be accomplished. Experts, please jump in and assist me with this please
Just to be clear on this: You don't route a midi track to an aux track. You route the midi track (the output) to your Fantom X8. So the Fantom will hear the midi and will output audio (which will go to the 1 & 2 (jack) inputs) , which you will receive on your stereo aux track (while it's INPUT is set to 1 & 2). Hope this helps... (ps. Why would you use an instrument track? I thought it was of more use for softsynths and not perse for a hardware one you have...)
One + minus one = zero |
Routing Issues - Aux Track and MIDI Tracks | MogDog | Virtual Instruments | 2 | 10-04-2013 01:41 PM |
5.1 track lay out, routing, metering question | vudoo | Post - Surround - Video | 3 | 03-29-2012 07:45 PM |
MIDI track routing problems.... | figment | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-24-2006 06:40 PM |
MIDI : Routing one track to two channels? | Muxlow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 10-29-2003 06:25 PM |
