Old 10-22-2011, 03:46 AM
gdrum gdrum is offline
Default Pro Tools 9 to 10 ilok will not surrender issue
Did a clean unistall of PT 9.0.5.....PT 10 does not recognize a license surrender in ilok, of PT 9 ???? and yet i see the license in the ILOK...
Anybody having that issue?
Thanks
Gregg
Old 10-22-2011, 05:04 AM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: Pro Tools 9 to 10 ilok will not surrender issue
Thanks
Gregg
No. It worked flawless here. But I deleted all PT/DAE prefs (incl.DigiSetUp) before I did the uninstall.
Then did a clean uninstall of PT9 using the uninstaller, installed PT10 HD, then ran the Avid_Virtual_Instruments installer, repaired disc permissions, started ProToolsHD10 and set up all the settings manually by using screenshots from previous settings (Hardware Setup, I/O SetUp, Playback Engine, Peripherals and PT-Prefs).
Cheers, STeff
MacPro5,1 , 32 Gig Ram, 2xATI Radeon HD 5770, OSX10.13.2  Pro Tools|HDX Ultimate 2018.4.0  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 10-22-2011, 10:56 AM
crizdee's Avatar
crizdee crizdee is offline
Thanks
Gregg
are you sure you have the right version on PT to match the ilok auth?
People are confusing pt10 and PT10 HD
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-24-2011, 06:13 AM
Thanks Cris,
You are correct.......PT9HD
Appreciate your reply
Gregg
Can not download Pro Tools 11 license to my iLok2 -incomplete license surrender issue StereoZzilla Pro Tools 11 10 01-04-2014 11:11 PM
ilok - Cannot download license: Pro Tools 10+9 Bundle requires surrender of license soukotta Pro Tools 10 10 09-25-2012 07:22 AM
ilok surrender PT 9 HD to 10 robi3furry macOS 2 01-11-2012 10:24 AM
Pro Tools 7.4 to Pro Tools 10 iLok unable to surrender. DS82 Pro Tools 10 9 11-13-2011 08:56 AM
ilok surrender license issue RichrdC Pro Tools M-Powered (Win) 4 04-27-2011 09:52 AM
