Old 07-09-2008, 03:08 PM
shultzee13 shultzee13 is offline
Default No other way than the Firewire 1814?
For recording at least 6 tracks at a time is there no other device than the 1814? I am looking for a cheaper alternative, but I need to record a whole band at one time. I think the 1814 will do 10 tracks at once which is awesome but expensive. Surely there is a way to record full bands on individual tracks other than buying a 1814 right? I have an Alesis mixer with firewire on it if that helps.
Just trying to make sure before I buy something this expensive (to me).
Thanks.
Pro Tools 11.3.1 & 10.3.8
Interface - Focusrite Clarett Pre2/Clarett Octopre
Computer - Mac Mini 2.5 GHz Intel Core i5, 16GB
OS - Yosemite
Monitors - Yamaha HS8
Old 07-09-2008, 07:47 PM
kafka kafka is offline
Default Re: No other way than the Firewire 1814?
It depends on what kind of inputs you need. Do you need mic pres, line inputs, ADAT, or S/PDIF?
Old 07-10-2008, 06:29 AM
Mic pres and line inputs
OS - Yosemite
Old 07-10-2008, 07:51 AM
spkguitar's Avatar
If you have an alesis mixer with firewire, you would probably have better luck with different DAW software. Pro Tools requires that you use either Digidesign hardware (for LE) or M-Audio hardware (for MPowered). Other DAW software (like Cubase, Sonar, Traktion) does not have that limitation, and can be used directly with the mixer you already have.
If you still wanted to use Pro Tools for mixing and editing, you could track using the other software and your mixer, then use one of the less expensive 2 I/O units for Pro Tools and import the WAVs for mixing and editing.
Old 08-12-2008, 12:54 PM
SixChurchStreet SixChurchStreet is offline
Default
www.novamusik.com has the 1814 for $319. I got mine from nova. You're not gonna get by much cheaper than that no matter what you get.
http://www.novamusik.com/search.aspx...ord=770&mid=54
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM El Capitan | 2011 MacBook Pro 2.0GHz 4-Core i7 8GB RAM El Capitan | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2018 | Studio One 3.5
Firewire 1814 is not working again DimitrisG Pro Tools M-Powered (Win) 11 11-06-2008 05:30 AM
003 vs. M-audio firewire 1814 legacygone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2008 07:41 AM
Mac Pro 2.66, Firewire 1814, 10.4.7 Imagine Pro Tools M-Powered (Mac) 7 09-21-2006 10:13 AM
Midi with firewire 1814? sethbrand Pro Tools M-Powered (Win) 3 08-14-2006 03:32 PM
Firewire 1814 Bill Pillmore Pro Tools M-Powered (Mac) 0 11-08-2005 04:38 PM
