Old 09-17-2020, 10:41 PM
bluenote1981 bluenote1981 is offline
Default Dock and Preview Issue
I've recently been working with the Dock but I cannot get the Preview button to turn Preview on in Pro Tools Ultimate 2020.9. When I select the ALT button the Preview Button is already Green. Pressing the button does nothing. The Preview soft key does turn Preview on and off in Pro Tools however getting to the button is an extra step or two. The firmware is up to date. I've tried power cycling and Vegas mode. Is there some preference that is causing this problem?
Old 09-21-2020, 01:40 PM
cabbagerock cabbagerock is offline
Default Re: Dock and Preview Issue
I'm having the same issue, anyone know a fix? Thanks!
Old 09-24-2020, 02:26 PM
creativecontrol's Avatar
Greetings,
Can you verify that your Dock Left Edit Soft Keys page looks just like this ->
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
Old 09-26-2020, 08:23 PM
Start Eucon and navigate to the page Jeff put in the previous post. Change the Preview soft key function to a different function. Doesn't matter which one.
Go back to the S1 and confirm that function you programmed is working.
Go back to Eucon and change the soft key function back to Preview. The S1 should turn Preview on and off using the button. A work around is to program one of the User buttons to turn Preview on and off.
Old 09-27-2020, 02:51 PM
Please let us know if others are also experiencing the same behaviors and if editing that soft key resolves it. Thanks.
Jeff
Jeff Komar
S6 FAQ
Avid Dock - Cubase 10.5 Issue with Wheel ANASON Records Avid S1, S3, Dock and Control 0 06-24-2020 10:50 AM
Issue With Automation in CPTK 2 - Capture and PReview hwill2008 Pro Tools HDX & HD Native Systems (Mac) 2 05-06-2011 11:54 AM
Issue With Automation in CPTK 2 - Capture and PReview hwill2008 macOS 3 05-04-2011 03:18 AM
PT 7.2cs2 audiosuite plugin preview issue asujazzcat Pro Tools TDM Systems (Mac) 2 12-29-2006 03:41 PM
Digi 002 -- Preview in this month's issue of EQ (eom) fred54368 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-07-2002 05:07 PM
