Old 03-26-2007, 07:56 AM
Ajay Malghan Ajay Malghan is offline
Default Digi 002r power supply issue
Hello all, I was wondering if anyone could steer me in the right direction for dealing with this issue. I have had the unit for 4 years and it finally has given up on working consistently. All the local stores can't help me since they say you have to contact Digidesign directly. Judging from my efforts in the last week I think I have a better chance reaching the Oracle. Should I wield my soldering iron to this problem? Any help would be appreciated, Thank You.
Old 03-26-2007, 08:46 AM
The Rockroom The Rockroom is offline
Default Re: Digi 002r power supply issue
The only thing I can suggest is that you persevere and contact Digi, they sure came through for me, and I was way out of warranty, but they still sent me a replacement power supply and that cured my problems permanently.
This was over a year ago though.
Good luck with it, I know how annoying it is.
Old 03-26-2007, 01:00 PM
jsteelman jsteelman is offline
What are the symptoms of a power supply issue? I currently have a problem in which the 002 disconnects from the cpu (Windows XP) and needs to be power cycled to reconnect. i already replaced the firewire card and cable so i thought maybe heat related...but now the power supply sounds like it could be the culprit. your feedback will be greatly appreciated.
G5 power supply issue emilano Pro Tools TDM Systems (Mac) 4 12-02-2005 12:10 PM
002 RACK POWER SUPPLY ISSUE Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-22-2005 06:51 AM
Power Harness Issue Digi 002R volts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-08-2004 01:06 AM
Power supply noise/G4 powerbook/002r ronfinch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-02-2004 09:59 AM
Power Supply Cabling Issue Armando ICON & C|24 1 03-07-2003 07:23 AM
