Bypassed plugins still introducing latency delay in template [solved]
Hi everyone.
I'm working on a group of songs, and want to keep pretty much all track, plugins, and plugin settings between them, so I created a Template from the first song. When starting a new session from the template, even with all plugins and sends bypassed, I'm still getting a bunch of delay and compensation on the tracks. This makes initial tracking a pain because of the latency. How do I get around this?
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 |
Re: Bypassed plugins still introducing latency delay in template
This is normal for most plugins, activate delay compensation for your sessions and it won't be a problem.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
plugins , also dsp , produce always latency while in bypass , for automation reasons f.e. , onliest way to reduce latency from plugins which are not needed , is to make them INACTIVE instead of bypass , but this is not
automatable , makes sense because you would have to deal with constant changing buffersizes and latencies and all its bad symptoms.
foley artist , soundeditor |
yes, delay is normal when bypassed, you can make the plugins inactive instead.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Thanks. That was the obvious thing to do that I was overlooking! Sent from my iPhone using Tapatalk
Delay latency problem in pro tools 12 with Izotope plugins | kevinkim | Pro Tools 12 | 0 | 11-17-2015 10:09 PM |
Plugin delay when bypassed? | TheWillies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-10-2010 05:53 AM |
Is The Same Sample Delay Incurred When A Plugin Is Bypassed? | Alan Brownstein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-05-2008 10:12 PM |
all RTAS plugins are bypassed | gw sound | Pro Tools TDM Systems (Mac) | 7 | 04-04-2006 09:23 AM |
Plug-ins are bypassed in Low Latency mode? | rune_sm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-07-2005 09:50 AM |
