HW device is at a different sample rate from the open session
When I open my Pro Tools session I get a error message saying "the HW device is at a different sample rate from the open session". I am running PT9 on iMac (2010), Mbox2 feeding TC Electronic BMC (monitor controller) via SPDIF. Session sample rate is 48 kHz. I can't change sample rate from Mbox2 or BMC-2. BMC-2 is showing that the sample rate is correct 48 kHz.
I just noticed from Session Setup window that the System Delay is 16632 samples, sounds high eh? I have to use Video Sync Offset of 32 qf and audio is not playing sync with the waveform. I am also having CPU overloads with my modest session. Any guesses what might be wrong? I have done all the usual preferences trashing. |
Re: HW device is at a different sample rate from the open session
One device has to be the master and one/or more the slave/s so in Setup>Hardware one device has to have clock set to internal (master) and the other to External (Slave). Click on ADAT radio button. If that doesn't work you may want to consider changing your handle...bad jitter might be a bad omen.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Ok, I discovered what was causing that huge system delay. It was GRM Evolution plug-in that on one track on bypass. Deactivated it and had zero problems today.
HW device is different sample rate AVID | john1192 | macOS | 3 | 10-15-2013 11:41 AM |
Can't Open Session- "because Pro Tools could not set Sample rate to specified value | Chopper | macOS | 4 | 06-27-2013 01:57 PM |
Can I open a session at a different sample rate? | benherron.rrr | Windows | 5 | 04-13-2012 03:49 AM |
Word Clock Issues "the HW device is at a different sample rate from the open session" | daveseviltwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-11-2011 06:09 PM |
Mytek + The HW device is at a different sample rate from the open session | glynnp | macOS | 2 | 10-20-2011 03:53 PM |
