20.1.0 automation mode soft keys still not working
Hello,
Does anyone beta test/use this stuff? I'm on ios 13.3.1, Avid Control on iPhone SE and PT 2019.12 1. Automation mode soft keys are still not working (read,touch,latch) 2. Redesigned pan graphs for channels are even smaller now, and there's a huge empty space in between stereo panners, is this a good move really? 3. Soft mode bar is missing from the bottom, is there a way to put it back there?
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11 |
Re: 20.1.0 automation mode soft keys still not working
How are you using the Automation softkeys? They work fine when programmed to some buttons in my old artist transport. I have to hold down the softkey and press at the same time a select button next to a fader to change its mode. Or hold down alt/opt on your keyboard and press the softkey to change all your channels.
Hi, thank you for your reply.
I use them in Avid Control app, on the Softkeys page. Atomation suspend works for example, but all the mode keys - Read,Write,Touch,Latch, Off do not have any effect on a track. If I go to the channel page and change automation mode from there, it works.
Have you tried Do to All and Selected.
mr Jones,
I do not understand what you are reffering to, i am afraid. No Artist Control or mix here. I am using only the Avid Control app, IOS 13.3.1 - on the softkeys page the buttons for changing automation modes - Touch, latch, etc, do not have any effect on selected tracks. Automation suspend button works, for example, plugin automation on/off button works, etc. What it is that I am missing?
After selecting a mode softkey you need to press, do to all or do to selected softkey for them to do anything
Sheesh! very sorry then. I did not know that. After modifying the buttons with do to selected command, the mode switches. Thank you! Reading the guide now...
Soft Keys - System Soft Key Display Mode | skilletaudio | Avid S4/S6 | 0 | 09-25-2019 09:07 AM |
S6 Master/Automation Soft Keys Not Working | MoreMe | Avid S4/S6 | 3 | 03-16-2018 11:08 AM |
Soft Keys 9-16 not working. | J-S-Q | Avid S1, S3, Dock and Control App | 2 | 05-19-2015 12:51 AM |
Lost Automation Modes Soft Keys in 2.5.6 | mystic merlin | Artist Series | 19 | 05-23-2011 02:21 PM |
HyperControl Instrument Mode Soft-Keys 3-4 | filosofem | MIDI | 1 | 05-19-2009 08:26 PM |
