Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 02-15-2010, 01:22 PM
JuanCarlos JuanCarlos is offline
Default keyboard drumming?
hi , i´m new at this , i just got bfd2 , i have pro tools 8 le, 003+, ..... i want to play bfd2 thru a keyboard interface but dont have a clu on how to do it....
1) where do i connect what types of cables (my keyboard doesnt have usb output , just midi)
2) do i connect my keyboard to my 003+ interface or directly into my computer??
Thanx so much
Old 02-15-2010, 03:08 PM
Default Re: keyboard drumming?
Keyboard midi OUT to the 003 midi IN. You might need to go into MIDI STUDIO setup and add a device, select a brand and model(similar if the exact model is not on the list) and leave all the MIDI channels in blue for now. Create a STEREO INSTRUMENT track, insert BFD in the top insert slot and it SHOULD work that easy(mine did). I also use a Trigger Finger on my desk, as well as a Roland kit with ezdrummer so I would expect you to get similar results. Good luck.
Old 02-15-2010, 07:56 PM
nst7 nst7 is offline
I see from your profile you're on a macbook pro. If this is the case, you should think about getting a midi to usb interface, available at most music stores or online dealers. Then you use the audio midi setup in Applications>Utilities. It scans the device and remembers it. Once you've done that, it will work within protools, garageband, or other recording applications, and standalone virtual instruments, regardless of whether your 003 is hooked up or turned on. It's just all around easier.
Old 02-16-2010, 10:28 AM
so , you think this would work? http://www.amazon.com/Cable-Converte.../dp/B0017H4EBG ...... it says midi to usb adapter , it looks like a cable ,
thnx
Old 02-16-2010, 10:59 AM
necjamc necjamc is offline
I personally have used this one, and it worked fine. I connect my roland concert piano midi out to it, and just leave it so its always there.
http://www.amazon.com/M-Audio-Midisp...6346670&sr=1-1
Old 02-16-2010, 11:43 AM
sunburst79 sunburst79 is offline
The Uno is excellent. I've had mine 5 years or so now.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-16-2010, 12:25 PM
+1 for the UNO. I have one on my rig and just installed another on a friend's HD/Mac Pro system and they both work great.
Old 02-16-2010, 02:04 PM
Thanx!, i´ll give it a shot
Old 03-02-2010, 02:47 PM
hi there , sorry to bug you with a continuation of the same thing...... u see i got the uno midi interface ..... i plugged in the midi end to my keyboard , searched it on aplications, utilities and it very well recognizes it ( it appears as uno interface) , but when i open protools and try and use it on.... let´s say the midi grand piano , nothing happens ...... i mean i can click the notes on it and hear them but i can´t control it from my midi keyboard........ the same with all my virtual instruments ...... the computer recognizes it but when i want to go ahead and play notes on the midi keyboard nothing happens..... am i missing some step?
Thnxs!
Solved my Drumming Nightmare... TreeDaddy Tips & Tricks 16 10-19-2010 05:42 AM
advice real drumming, midi drumming boom/strike ?sequencingin epiphone The Drum Room 9 01-18-2010 07:33 PM
bfd VS. Reason for drumming rpb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-03-2004 05:14 PM
BT Question on Drumming Kenny Gioia Tips & Tricks 15 05-05-2003 10:48 PM
Better drumming through protools use pkcraft 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-20-2002 09:46 PM
