Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 08-22-2020, 01:15 PM
lampmusic lampmusic is offline
Default CPU Maxing out Random
System Specs: 2019 / 16 MPB 2.3 / I-9 with 32GB RAM.
Latest version of PT running os 10.15.4 interface: Focusrite clarett TB2 with adapter.
The past 3-4 months I would suddenly get what appeared to be random CPU spikes in the System Usage gauge. This wouldn't happen every time but when it did PT would not play at all.
Interesting observation: Even with a session closed sometimes the CPU spikes would still show in the system usage.
After doing some searching I still couldn't seem to come across any troubleshooting info about this issue.
I looked into 3rd party plugs that might be causing this.
Then I was able to clear it up almost instantly by raising the fan speed in the macs fan control app or putting the fans back to automatic.
I have been using the fan control app for a year or so because the fans are so loud when I'm using PT that it's disturbing.
Anyway so far it appears that there may have been been some 'heat throttling' that was causing PT to go ape.
Has anyone else experienced this? If so am I on the right track to resolve it? Any other workaround?
Thanks
Running Pro Tools 2021.12
Main System 2020 M1 Macbook pro 13 inch / 16MB Ram / 1TB SSD / Big Sur
Future System 2021 14inch M1 Pro / 16MB Ram / 512 / Monterrey
Old 08-22-2020, 01:59 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: CPU Maxing out Random
Never try to control fans yourself. If you set the fan(s) off or too low, the CPU will overheat and once it does, CPU itself will slow itself down, which causes CPU spiking.
The new laptops apparently are not so good in thermal performance, you just need to accept the fan noise.
Janne
Old 08-22-2020, 08:45 PM
The fans on my MBP 16 are hardly noticeable until I boot up Pro Tools then it sounds like they jump to max.
When looking at the internal temps nothing seems too high.
Old 08-23-2020, 08:52 AM
audiobob's Avatar
audiobob audiobob is offline
That happens because Pro Tools uses the AMD Radeon 5500 dedicated graphics card. That card is known to draw lots of power and drains the battery very quickly. That's why the fans kick in high gear when using PT.
I hear there is software that turns off that card...but haven't tried it.
Old 08-24-2020, 07:25 AM
I've had good luck using Turbo Boost Switcher to turn off overclocking, which has managed to noticeably reduce the fan noise in my 2019 i9 MacBook Pro.
Scott Gatteño
Old 08-25-2020, 02:33 PM
huzzam huzzam is offline
yep that's a good thing to try. i used to do this on my old 2011 mbp, because the integrated graphics were enough for pt and it ran much quieter. I used this utility, i'm not sure if it still works in the latest os's or latest macs: https://gfx.io
In any case, as mentioned, your problem is almost definitely thermal throttling. Let your fans run normally, please; otherwise you're gonna be bumping up against the thermal limits constantly, and get spikes, crashes, and finally system instability. you could add a cooling mat under the laptop if you want to try to help the cooling situation. Or connect an external monitor/keyboard/mouse and put the macbook in a closet with sound treatment, if the noise is really unbearable...
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 08-27-2020, 12:34 PM
daeron80 daeron80 is offline
Good info, guys. Appreciate it. In the past two days I've been getting this on my Mac Pro Trashcan, which has run PT flawlessly for six years, and has run 2020.5 flawlessly since June.
Yesterday morning, I was setting up for a voice over session. One track, three light plugins. PT locked up for several seconds when I put it in record with cores hitting 100%. Restarted, opened PT, everything fine. Talent got there, suddenly, the computer is freezing up for anywhere from a few ms to several seconds at a time, randomly and frequently. Thankfully, I had a Sound Devices 702 at hand, which I quickly patched in and recorded to. Since that session, I've been editing in an hour-long, six track session with video, and several heavy plugins on each track - so heavy that bounce down runs at only 5x. Not a hitch until a few minutes ago when PT suddenly started freezing up the computer again.
I take it I have an overheating issue of some kind going on. I mean, this beast is six yeas old, and I accidentally overheated it once on a remote job two years ago. Maybe it's just the CPU showing its age.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Maxing out an HD3 Rig Titans55 Pro Tools TDM Systems (Mac) 5 11-26-2010 12:00 AM
For anyone who is having the random white noise burst / random distortion problem Philly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-23-2010 04:56 AM
CPU Maxing out taXe Pro Tools M-Powered (Win) 5 11-08-2009 04:35 PM
Maxing out cpu on laptop with 7.0 Driveteam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-22-2006 09:14 PM
-9073 and -6086 DAE Errors RANDOM, RANDOM, RANDOM mikerica101996 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-13-2004 01:08 PM
