Compacting Files
I've succesfully compacted files in sessions many times, but today every time I tried to compact, my computer froze and corrupted the regions it was working on. Unfortunately I had not backed up before running the compact function and I lost some data. Any suggestions or ideas on what would suddenly cause the compact function to stop working properly? (Tried it in 2 different sessions with same result) [img]images/icons/mad.gif[/img] Thanks.
Re: Compacting Files
I had the same problem you had until i realized something.....my computer just didnt freeze!!!
Compacting is a quite complicated process somehow, and it takes a while (20 min's or so)on a heavily edited song. Digidesign mad a minor designflaw in the progress-bar. It stops, and you think your system frooze, but in fact it is working hard...... To avoid the risk of losing your session, do a "save session copy in" and check the "copy audio-files", and perform the compacting on the copy, not the original. Then check wether everything is still there, and then delete the old session with its audio-files.
What's that? - That's the machine that goes "pling". Bastiaan |
I thought that this might be the case, but when hitting cntrl+alt+delete to bring up the task manager, it says PTLE is "not responding". Is that also normal? I thought that meant the program was toast until shut down. [img]images/icons/confused.gif[/img] Thanks.
You will often see "Not Responding" on programs that are busy running a batch process.. I have seen this a hundred times on 3D projects during the rendering process, as well as other cpu task intensive processes. This is normal and a little misleading.
|OS 10.2.8|80gb ATA100|120gb ATA100| |Mac|FW800|DP 1.25ghz|1.5gb Ram| |PTLE 6.1.2|Digi002r|Digimax| |Recent PC to Mac convert| |
Thanks for the help. I guess my lack of patience got the best of me once again!
Compacting .wav files | Reckless Erik | Post - Surround - Video | 0 | 02-10-2006 04:11 AM |
compacting files and clearing unused regions | Rasan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-11-2004 08:56 AM |
Compacting Audio Files/"Too few samples" | Dennis Scott | Pro Tools TDM Systems (Mac) | 2 | 01-28-2004 12:05 AM |
hang up when compacting selected files | Capi Baigorria | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-18-2003 09:06 AM |
wav files in 5.1.3 when compacting audio | leebeefunny2 | Pro Tools TDM Systems (Mac) | 0 | 06-28-2003 02:45 PM |
