Track not in sync after inserting plugin
Appreciate help as to why this happens. For example I inserted a
Waves Supertap on the lead vocal track, and now its not in time with the mix. I also have a compressor & reverb inserted on the vocal buss as well. Thanks, Steve |
Re: Track not in sync after inserting plugin
Supertap has a lot of processing latency and will delay your track... are you using ADC? (PT HD only) If you are recording with Supertap then you should ditch the plug till mixdown... if you are LE then you are in the wrong forum...
HD1 - This is happening during mixdown.
Not sure what ADC is? Analog Digital Conversion? |
In this context ADC means Automatic Delay Compensation.
Kind regards Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
I'll, check, is ADC located in preferences?
Thanks |
The answer to your question only begs more questions.
Take a minute and pop the manual.. you will be glad you did! SB |
Thanks for pointing me in the right direction guys. ADC was off, and ended up nudging
the track a little as well... |
ADC is also effected by your hardware buffer settings! (in playback engine settings) The higher the buffer setting the longer the delay caused by plugins!! (but this setting can give you more RTAS performance) Reducing the buffer gives you lower delay readings on your plugins, but can cause playback glitching if the buffer is set too small. Chris
Macro for inserting a certain plugin... | GW | Artist Series | 3 | 02-03-2011 10:32 AM |
Why does audio stop when inserting 1st plugin? | GroovnD313 | Pro Tools TDM Systems (Mac) | 5 | 04-14-2008 04:33 PM |
OT: Inserting track ids on CDR | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-04-2003 12:22 PM |
Please help! Inserting track numbers in Jam? | Joseph Grimm | Tips & Tricks | 5 | 03-14-2001 11:43 AM |
Inserting new track problems | ribarr | Digidesign Hardware & Software | 0 | 10-28-2000 12:54 AM |
