Old 07-30-2007, 08:50 PM
fiddler69 fiddler69 is offline
Default Mic\'ing help - fiddle
As my user name says - I'm a fiddle player. I'm doing some work with one of my
buddies in his home studio. We have yet to really be able to get a good fiddle sound. Well at least
not one that I'm happy with. I want that full bodied fiddle sound. I know it starts with the instrument - and I have a decent one. Does anyone out there have experience with recording fiddle for country or bluegrass music. If so, what mic do you use? And how do you mic it? If you could make a good, better, best - mic recommendation what would the options be?
Thanks !
Studiocat Pro Studio "Modified"
2x500GB 1x250GB 4GB RAM Q6600 @ 3Ghz
Abit P35 MOBO 2xDell 19" monitors
Mbox 2 Pro,
KOMPLETE 5,
EZdrummer w/Nashville EZX
M-Audio Pro Keys 88.....M-Audio Axiom 49
UA-LA610.....AT4040.....AT4047
M-Audio BX8a Studio Monitors
Old 07-31-2007, 01:24 AM
NickH NickH is offline
Default Re: Mic\'ing help - fiddle
Try placing the mix about 6 feet away and slightly above the fiddle...
Cheers
N
“It’s because you touch yourself at night... ”
System Specs
Old 07-31-2007, 09:18 AM
Craig F Craig F is offline
AKG C-28 w/ ck1 cap., 3 to 4 feet above the instrument is were I tend to get the best results
Thank you,
Craig
Old 07-31-2007, 10:16 AM
DanoWpg DanoWpg is offline
I've had success with either an AKG C535 EB or a Neumann KM84i. As previously stated, try to get some distance from the instrument to get more of the tone from the body.
Digi 002R Factory/
PT 8.0.5 on Mac Pro 2.4 - 8 Core (Westmere), /Mackie Onyx 800R/Focusrite ISA 428/Waves Studio Classics Collection/CLA Classic Compressors/Massey Plugins/Breverb 1.5.1/Presonus Central Station/Genelec 1029A
Gigabyte GA-X58A-UD3R/Intel Core i7 930/6GB OCZ Triple Channel/NVidia 8500GT 512 (Silent)/PT 8.0.1
Old 08-01-2007, 07:49 PM
sw rec sw rec is online now
I've actually had real good luck with, dare I say, an SM-57! My favorite setup, though, is an Audio Technica 4033 near the body, and an AKG 451 about the middle of the neck. You'll have to move them around a bit to find what works best, and record two MONO tracks instead of one stereo, so you can mess with processing until it sounds the way you want it to.
"If it sounds right, it is right" (Joe Meek)
Old 08-01-2007, 09:03 PM
jimmyd3 jimmyd3 is offline
I just worked with one of the top fiddle players of our time and he brought his own mic of choice and it was a Neumann km86 which I have found to be one of the most under-appreciated mics of our time. I ran it through a UA-610 and it sounded great. It was 12-15" from the instrument. Hope this is helpful.
Old 08-15-2007, 10:53 PM
Barnabas Barnabas is offline
AKG C451 or similar small diaphragm condenser mic about two feet above.
www.barnabas.com Barnabas MultiMedia
Old 08-16-2007, 01:00 AM
nonsqtr nonsqtr is offline
"Okay" - actually "not bad at all" is an SM-57 - boost 3db at 10 kHz on "most boards"
"Good" - AKG C451EB - this works well if you take out some of the nastiness in the "string noise" range
"Better" - Neumann KM-184 - great all-purpose mic, works well on "almost" anything
"Best" - Neumann KM-54 tube mic - the one with the nickel capsule - oooh, sweet
Let's see, there's really lots of possibilities once you start getting into the bucks-up range.
For my money, for instruments, I like the vintage mics, with one exception - I'd like to have a nice Royer ribbon mic in my arsenal. Those sound awesome on "lots of things", and they're surprisingly good on acoustic instruments. You'll need a good pre though, they're very sensitive.
Old tube mics - AKG C-61, that's a great one. Use that one "a little closer" to your instrument, it really likes close-up mic'ing. That's in the thousand-dollar range. Um... some of the old Pearl (PML) tube mics are really awesome sounding too, they're getting hard to find though. If you can find 'em in good condition they're also in the thousand-dollar range. One of the big advantages of those, is you can get 'em as close as you want to the instrument - heck, you can clip 'em right on there if you want. If you really want the "sound of the body" of your instrument you can get that very easily with judicious mic placement of, say, a PML EC-71. And, the old nickel Neumann's, just about any of those will sound absolutely spectacular with the right placement (you can pick and choose your desired directional characteristics, and I would absolutely run those through some kind of vintage pre, like a Neve 1290 would be the perfect match for a KM-54 with a violin - and I'm guessing a fiddle would be "similar").
For new mics, I do like some of the Blue mics, you can find those locally, the Dragonfly or Cactus or one of those, ought to work well with fiddle. Blue is an interesting game - you kinda have to mix'n'match their capsules to find out what sounds good. I had them make me a set for a CMV-563, and they ended up sounding much MUCH better than the originals. Think, like, the precision of a 184 with the warmth of a tube mic - that's kinda the end result. If you're really interested in spending big money, contact BLUE - but you'll definitely get your money's worth, those guys are some of the best when it comes to the real hand-made high-end stuff. Plus they can work on almost "anything", they can make adapters and stuff, you know like if you have a set of bayonet capsules you want to use with a screw-in base or something like that.
But yeah - at the end of the day, I really have to echo the above-mentioned earlier sentiment (shhh.....), and note that some very excellent recordings can be gotten with an SM-57. Cheap, industry standard, buy 'em anywhere, most boards "like" 'em, and really, they're very nice mics. If you have a good EQ or if you're using ProTools or something, no problem - you definitely should be able to get a decent track with a '57. I'll defer to the above fiddle playing experts for mic placement ("experiment").....
I need a Fiddle player in LA DrFord General Discussion 7 09-07-2010 07:44 PM
Fiddle anyone?????? danander11 Virtual Instruments 8 01-14-2010 07:29 PM
A Scratchy Fiddle... bigcow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-12-2004 09:29 AM
A Scratchy Fiddle... bigcow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-12-2004 07:08 AM
Recording Fiddle Beegster Tips & Tricks 9 04-16-2001 08:02 AM
