Mbox & Tibook to replace AM3??
Hey Guys,
Been using my good ol' 8600 & AM3 card for years, usually for transfering audio from my Adats/DAT via spdif to ProTools with the AM3 (all controlled with BRC remote). I've been using a TiBook (G4-400) with PTools Free for about a year now. I transfer mixes done with AM3/8600 via network or Zip to the Tibook to make use of vastly quicker processing. I'm pretty tired of this transfering process, but I don't want to drop a few thousand on a magma / 001 set-up to work with the Tibook....so...this brings up a few Mbox questions I would appreciate some help with: 1) From researching "slower USB speeds" Mbox posts here, can anyone suggest if 1 or 2 track transfers via Mbox spdif are smooth in real-time or are there hiccups? 2) With my 8600, I often run PTools "on-line" to accept sync from my SMPTE/Midi converter which is plugged into a serial port. If I were to attempt analog or spdif transfer to Tibook with Mbox, would I be able to use a MIDI-to-USB adapter to allow PTools with Mbox to "slave-sync" as I'm doing now with 8600/AM3? Would I be maxing out the Tibook expecting it to run smoothly with Mbox in 1 usb port while running Midi to the second usb port? Looking forward to suggestions for proven USB-to-Midi adapters, and answers. Thanks. -John J.
MacPro 2.66 8 core • 24G ram • Lotsa Terrabytes OSX 10.8.4 • MBP Core i7 C|24 • PT 10/11 HD • Reason 6 www.icedrum.com |
mbox > 002r with 800 tibook | eboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-29-2003 03:09 AM |
PT6 & TiBook mBox | btovsky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-14-2003 09:38 AM |
TiBook/MBox heat | nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 05-26-2002 06:30 AM |
Mbox on TiBook with two monitors? | yin7yang64 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-18-2002 10:30 PM |
TiBook, Mbox | purduematt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-17-2002 05:55 AM |
