MIDI drum file not playing in PT9
Hi. I'm new to Pro Tools, but I have been producing MIDI backing tracks using Sibelius for many years. I have a whole library that I want to convert to Audio(wav?) but mainly to make use of the great instrument sounds available in PT9.
I've successfully imported a MIDI file into Pro-Tools and managed to assign instruments to each track. They all work except for the drum tracks!! I tend to use 2 staves in Sibelius for drums: one for percussion (cymbals) and one for kick,snare, toms, etc. I've tried using Xpand2 and BOOM but I'm unable to get any sounds to play. The vu-meter shows activity, so I've obviously not got the path configured correctly or is it that the VI's for drums only respond to single drum lines? I don't want to have to re-write the drume tracks for every single backing track to have a line for each drum/cymbal. Is there a VI plug-in that will play the file with multiple drums? Any help would be appreciated. Looked through FAQ's and can't find anything specific to my problem. |
Re: MIDI drum file not playing in PT9
Problem partially solved!!
I hadn't copied the drum files into the instrument tracks. The bad news is that the drums don't sound the same as they did in General Midi - the same notes don't trigger the same drum items - especially the cymbals. I used Xpand2 pop kit to try it out. |
There are some vi's that sort of follow the GM mapping but they don't have all the sounds. BFD2 is one of those. |
Pro tools 10.3.2 not playing imported midi file | kevinpierce93 | macOS | 2 | 12-29-2012 05:22 AM |
Midi- Roland Keys playing EZ Drum and Reason at same time | sweepsr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-21-2010 07:34 AM |
Question: Converting an audio drum file to a MIDI file? | ctyelvis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-18-2010 06:56 AM |
MIDI Drum Track Not Playing | bmcoonan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-18-2009 03:23 PM |
easy way to convert a real kik drum into a midi file with 7 | airtonemusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-22-2007 11:47 AM |
