Any way on PC to refresh 003 FireWire connection when unresponsive?
Win 10 Home version 1703
Pro Tools 12.8 003 console Understanding that hot-swapping the cable will cause damage and therefore not an option, is there any software-based way on the PC, short of rebooting, or control sequence on the 003, to refresh the FireWire connection bewteen the 003 and PC when it gets lost and won't fully respond when a session is launched? |
Re: Any way on PC to refresh 003 FireWire connection when unresponsive?
Troubleshoot what is causing this and fix it.
Most common cause of stuff like this is allowing the computer to sleep/suspend. You can't let the computer do this, which is why disabling power management is a part of standard computer optimization (have you done that). Or you need to power down the interface first. If that is not it describe exactly what is happening, when exactly it "gets lost" and what exactly that means. 003 driver version? Sandra report? Firewire card. What else is on the Firewire bus?... |
Indeed^^^ in 5 years of running my 003 on 3 different computers, it never "got lost". Swapping for a new FW cable would be step #1 for me as they can fail for no apparent reason at all(learned the hard way). Having said that, simply switching the 003 power off and back on should be a safe move
but power cycling the 003 will not address the computer "losing" the 003 because it slept... for that you need to reboot the computer.
Absolutely true and why sleep and hibernate need to be disabled on any Pro Tools machine
Finally getting back to this... will post Sandra and other specs shortly, but first wanted to ask about this:
thanks in advance... |
I hope you didn't "hot swap" the firewire cable? Never, ever do that. Make sure both the computer and 003 - or any other firewire device - are stone cold off. I've already paid for that educational lesson. One reason I run my RME UFX with USB rather than the also available firewire connection.
I also learned that one the "expensive" way $327 later, I worked that 003 for another year of no problems until I made a major upgrade. While I never intentionally "hot-patched" it, I likely bumped it as my path to the vocal booth went behind the desk
PT 12.7.1 would not see my Firewire connection! | Chopper | Pro Tools 12 | 1 | 04-30-2017 09:29 AM |
firewire connection ? | bscism | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-18-2011 06:16 PM |
Midi connection causing stop command unresponsive | losrack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-28-2010 02:12 AM |
PT 6.9 & 002 Firewire connection HELP!!! | narnia040 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-18-2005 08:02 PM |
002 firewire connection ok? | doubleyouel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-23-2002 01:58 PM |
