Old 04-25-2005, 05:51 PM
a2zproductions a2zproductions is offline
Default 6.9 Default to Auto Latch after Write Automation..
What is with this change. 6.9 defaults back to Auto Latch
after you stop your Write Automation. It used to be Auto Touch
after stop. Is there a way to put it back. Or to continue with
Write after stop?
P.S. Installation went just fine!
Thanks,
Adrian
Old 04-25-2005, 09:21 PM
Danny Caccavo Danny Caccavo is offline
Default Re: 6.9 Default to Auto Latch after Write Automati
There didn't used to be a "latch" option for this. It was added for Pro Tools 6.9. The reason we changed the default to "latch" was because "latch" is more similar to "write" than "touch" is.
If you like it the old way, you can just change the preference.
Danny Caccavo
Digidesign
Old 04-26-2005, 12:38 PM
Where can I change the preference in LE?
to default to autotouch after write?
Thanks,
Adrian
Old 04-28-2005, 09:47 AM
Hello, anyone there?
A.
Old 04-28-2005, 10:23 AM
In your preferences.
You should try using it with the new default though.. the changes to touch automation make the new default a much smarter way to mix.
The only time to use touch automation now is for fader snap back mode.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-28-2005, 10:32 AM
SessionKat SessionKat is offline
Rail
Rail is sooo right on this. You will find Latch the preferred way to automate your mixes instead of Touch.
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Old 06-21-2005, 08:37 AM
Headmxr Headmxr is offline
Whether you like Touch or Latch is a personal thing, but the fact remains that the Preference box to choose either is missing in LE. I'm still waiting for DD tech support for an answer. They have confirmed this issue.
Old 06-22-2005, 09:03 PM
Was just told by DD tech support that the missing Preference box is a bug. They are "working on correcting it".
Old 02-20-2006, 12:10 AM
lesoufs lesoufs is offline
So after the time will Digidesign send an update for Protools 6.9 LE about the "missing" write to touch automation option????
I hope that we don't have to get to Protools 7 for an utility that what in protools LE for SOME YEARS...
G5 2 Ghz, Digi002, Protools LE 6.7, Logic Pro 7.1 Mac OS X.3.9 / T61 vista Protools 8 for the road Paris France
Automation Write Enable default? dustin_m macOS 0 11-21-2012 02:35 PM
003 Surface auto write/latch/touch buttons not working Arya44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-19-2009 10:35 AM
Can't create automation using write/latch feature Jambroch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-30-2008 02:50 PM
Write and latch: is there a real difference? cinetj Tips & Tricks 2 12-16-2007 12:19 PM
Write defaults to Latch instead of Touch in LE6.9 Headmxr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2006 12:27 AM
